RC51 No Start/ No Spark - Speedzilla Motorcycle Message Forums
post #1 of 4 (permalink) Old 06-03-2016, 07:05 PM Thread Starter
xrocket21's Avatar
Send a message via AIM to xrocket21
2003 RC51 with 30k miles, speedo healer, old fuel commander (not usb)
I have owned this bike for almost 10 years.
Last August, I rode 50 miles to work, took it on a 15 mile ride at lunch, then 40 miles into my 50 mile ride home, cruising at 40 in a 35 on flat ground, the engine simply stopped. Not a sputter, not a backfire, just turned off. Never had a flicker on the dash, no FI light. Turned the bike over, strong battery, engine showed no signs of life. Fuel pump cycles.
I tore the bike down and there is no spark to either plug.
The coils were both replaced around 6 years ago.
I have a factory manual and went through some diagnostics.
I also tried removing the fuel commander and it made no difference.
I have solid continuity from the yellow wire on the ecu to the ignition impulse generator. The wire insulation is slightly chaffed at the plug, but the copper is un damaged.
I measured the voltage at the ignition impulse wire and the book says the voltage needs to be at least 0.7 volts, I get 0.4 volts max.
I replaced the ignition impulse generator, and still have no spark.
Im pretty pissed/frustrated at this point. And I have toasted the battery from it sitting and screwing with it off and on trying to fix it.
Any advice on why I don't have spark would be MUCH appreciated.
xrocket21 is offline
post #2 of 4 (permalink) Old 06-03-2016, 09:18 PM
my suspicion would be the Cdi. see if you can borrow a known good one to try
wibbly is offline
post #3 of 4 (permalink) Old 06-16-2016, 02:01 PM Thread Starter
xrocket21's Avatar
Attempting to repair the cdi
HOW TO fix broken converter SP1 - SP2 - Honda RC51 Forum : RC51 Motorcycle Forums
post #4 of 4 (permalink) Old 06-21-2016, 11:49 AM Thread Starter
xrocket21's Avatar
CDI repaired! It was the transistors after all!!!
Human Verification
