Old 07-25-2005, 02:11 AM
Default ohlins shock and battery?
How do i adjust ride hight a rear ohlins and penske shock
what is the smallest battery i can use and still crank over a higher compression hawk.
had to edit i get long winded
Modified by pit at 5:31 PM 7/26/2005
Old 07-25-2005, 03:15 AM
Default Re: penski shock and battery? (pit)
I don't know what model shock you have, but on both my fox and penske, there is a lock nut on the threaded clevis at the bottom of the shock, below the rebound adjuster, which if you loosen, will allow you to raise or lower the shock height...provided your model shock has ride height adjustability?
don't know about the battery...ytx-7 maybe?
