What tires should I get? - Speedzilla Motorcycle Message Forums
Old 12-19-2005, 07:45 PM
macfartlane's Avatar
Use the Force Luke.
Smile What tires should I get?
Looking for any info on the widest tire I can put on the rear without rubbing the swingarm....and a front to match.
Street use only. Stock rims
Any info would be greatly appreciated.
Thanks, Eddie
Old 12-19-2005, 08:41 PM
I am using a 120-17 on the front and a 180-55-17 on the rear and have about 2mm of clearance left! Both tires are Dunlop 208's. I am also using a VFR rear rim and a 600RR front tim.
Hope this helps..
Old 12-19-2005, 09:43 PM
Use the Force Luke.
Default Thanks Shiggi
I just added that I'm running stock rims, in case that will make a difference. Thanks for the info, I've heard good things about those Dunlops. Eddie
Old 12-20-2005, 01:07 AM
I think 160's are the widest you can run on the stock rear rim. I just bought a set of Michelin Pilot Road's. I went 110-70 on the front and 160-60 on the rear.
They're awesome tires...Michelin's have always been on my vehicles since I first discovered the improvement to the ride.
Old 12-20-2005, 05:05 AM
Default Tires
+1, 160/70/17 , You Can Do 110/80 Up Front, But That Changes Handling Characteristics. Stick With 110/70/17.
Old 12-20-2005, 10:48 PM
Diablos in the sizes closest to stock have worked the best on my bike.
Old 12-26-2005, 07:04 AM
RxRC's Avatar
calculating status...
You should definetely go with the 110/80 in front. Even that is a little short, but it's the best we can do.
Old 12-29-2005, 02:00 AM
bmxr's Avatar
I liked the way 110/70's felt on my Hawks. Threw the speedo off but what do I care?
btw-the 180 is WAY off for that rim. 170 is too big, too. Fitting tires based only on swingarm clearance is a very uninformed way of doing things. My SVS with 25hp more than my built Hawk, doesn't want for traction with it's 160 rear ...
Waiting for the KTM 690SMC...
Old 12-29-2005, 02:17 AM
oneducs's Avatar
wider tires do not make for a better handling bike. i would stick with the stock size tires. what are you looking to do with your bike?
