Clutch ?'s - Speedzilla Motorcycle Message Forums
Old 10-12-2005, 07:39 AM
mr3436's Avatar
Default Clutch ?'s
Im looking for a replacement clutch. Motor is pretty stock except for stage 1 jet kit, Unipods and Supertrapp. I really dont want a heavy clutch but a little firmer over stock wouldnt be bad. I will eventually build up the motor but I need a new clutch first.
Should I go after market? ie Barnettt What's the real benefit if my motor is still pretty much stock or should I just stick with stock plates and just get stiffer springs?
Old 10-13-2005, 02:36 PM
jhord's Avatar
It depends what shape your current clutch is in. If just the frictions need replaced, (ie the metals are good) it's the cheapest way to go, around $60 or so. If the metals are blued/warped, then replace with the whole pack from Barnett. ($120) You can use either 2 or all 4 of the Barnett springs to tune the lever feel to your liking. With 4 it is a good bit stiffer than stock, but not what I'd personally call bothersome... ymmv.
J.D.
Old 10-23-2005, 04:05 PM
So how long can a stock clutch be expected to last?
I have 38,000 miles on mine and it still is working fine.
John
Old 10-25-2005, 02:11 AM
RxRC's Avatar
calculating status...
John
Certainly depends on how you treat it. Neither one of my friends Hawks made it to 20k without needing friction plates.
