Two years ago I had an occasional drip-leak issue with my water pump cover. After two attempts to seal the leak, I finally replaced the water pump cover. I was told at the time that although it was a fix, it was a temporary one because the technician suspected both the crank cover and the water pump cover had a hairline crack. At teh time I coudl not afford a crank cover.
Well two years later, my I now have a leak from the exact spot, so needless to say i need a crank cover.
Where can I get an aluminum version of this:
