Old 07-28-2009, 01:06 AM
2wheeldaddy 2wheeldaddy is offline
Default torque numbers?
Can anyone help me with this. I have a vibration problem with my 2002 998 and found that the engine to frame and swing arm bolts were loose. Does anyone know the actual torque numbers. I'm going to order a service manual but in the meantime I want to fix this ASAP.Thanks
Old 07-28-2009, 02:03 AM
TrickLidz's Avatar
TrickLidz TrickLidz is offline
lidzduc.blogspot.com
This should get ya in the ballpark-
Ducati.com || Bikes || Ducati Service || Tech Data
http://www.speedzilla.com/forums/signaturepics/sigpic6094_1.gif2003 999R
1999 ST2
1998 748
2006 R1200RT
My Knols-http://knol.google.com/k/steve-methia/-/2rk7csiieinrp/0#knols
Old 07-28-2009, 04:42 AM
Thanks. I thought that maybe the 998 was different. I will use those specs for now until I receive a service manual.
Old 07-28-2009, 11:54 AM
i find really tight works a treat.
Brad The Bike Boy
www.bikeboy.org
Old 07-28-2009, 11:40 PM
dus10r dus10r is offline
Swingarm Pivot Bolt 73Nm
Engine to frame screw fixing nut 60Nm
Engine Mounting Bolt 44Nm
These are from the Testastretta Workshop Manual
_________________________________________________
Old 07-30-2009, 02:03 AM
Thank-you very much. If I understand you correctly, I torque the nut on the end of the bolt tighter than the head of the same bolt? The bolt probably threads into the engine cases then? I learnt something new today.
Old 08-04-2009, 06:05 AM
BC999S BC999S is offline
Can Afford To Be Critical
Nope.
