Featured Photos
by Jes_VFR
Intersting wrecks
1 photos
0 comments
by Turnone
Member Galleries
2078 photos
644 comments
by Yossarian_47
Member Galleries
2078 photos
644 comments
by juicedstang999
Member Galleries
2078 photos
644 comments
Old 09-21-2008, 09:48 AM
apfelbaum apfelbaum is offline
Default Need a little guidance and info
Hello all, my gf and I acquired a Ducati Monster S4R (996 motor) a few months ago. After riding the tires off of it for a bit it is time for the major service. So far here is where I am:
Oil change done
Filter change done
Oil strainer cleaned.
Timing belts changed
Plugs after the valve adjustment..
Now for the questions:
Can someone please give me the specs for the valve clearances (hopefully in mm, my feelers are mm) ? I didn't get the right manual for this bike from the dealer, in fact if anyone has the right manual I'll be happy to trade, I have the 07 model manual with the newer motor.
Is it better to make the adjustment with the timing belts loose or tight? (they are still loose)
Anything else that you guys can recommend while I have this thing apart?
I also plan on getting a vacuum gauge and checking oil pressure as well as sync the throttle bodies.
Thanks in advance.
Old 09-21-2008, 02:53 PM
ducxl ducxl is offline
Location: Bristol, Rhode Island, U.S.A., Bristol, Rhode Island, U.S.A.
Here's a link that may be of help.>Guide to adjusting Desmo valves.
<Mine,generally ,are set from .004-.006 inches clearance
Old 09-22-2008, 05:42 PM
Thanks so far, however, this is the only thing I have found so far:
"NOTE: 4v motors have a whole different set of clearances, on the looser side of the 2v. I am only listing them here as
reference.
Intake openers: .003"-.005"
Exhaust openers: .005"-.007"
Intake closers: .000"-.004"
Exhaust closers: .000"-.004" "
I'm not sure this is it. And it also doesn't state if this is to be done with belts loose or tight. When I convert these to milimeters I get:
intake openers: .076 to .127
Exhaust openers: .127 to .179
intake closers: .0 to .10
exhaust closers: .0 to .10
I know the Europeans like to work with more whole numbers so:
intake openers: .08 to .13
exhaust openers: .13 to .18
closers as stated
Does this seem right? I've found plenty of reference for the the 2V motors but not a whole heck of lot for the 4V motors. Anyone that has a 996 motor and has done their own maintainance, your guidence would be very much appreciated. BTW the info came from here:
Ducati Suite- Valve Adjustment
Again for the 2V motor, but everything should apply to my motor except for the distances.
Thanks again for any help.
Old 09-22-2008, 07:34 PM
916duc's Avatar
916duc 916duc is offline
Default Valve specs
Name:  Ducati valve specs.jpg
Old 09-22-2008, 09:39 PM
Ben710's Avatar
Ben710 Ben710 is offline
This is what my 916/996SPS workshop manual says on page 62:
A) Opener
intake, mm:
0,05 ÷0,15
exhaust, mm:
0,05 ÷0,20
B) closer
intake, mm:
0,13 ÷0,25
exhaust, mm:
0,08 ÷0,20
powerwheelie racing weblog
Old 09-22-2008, 10:12 PM
infoage1's Avatar
infoage1 infoage1 is offline
I tend to target Bruce's specs:
Ducati Desmo 4-Valve Clearance Chart
Tom - S4 Foggy, 996R....
Old 09-23-2008, 02:11 AM
Ducman851 Ducman851 is offline
Way to go Tom
Welcome to Users.adelphia.net server!
The page you have requested was not found on this server. That could be caused by several things:
  • The URL you were trying to retrieve was mistyped
  • The URL used to exist but has been changed
  • The customer account has been removed
If you are a former home.adelphia.net customer who has not yet created your users.adelphia.net account, you may do so by going to the User's Migration Page, entering your current home.adelphia.net username and password. Your account will be created automatically.
Note: that since the period for migrations has passed, we will no longer be able to retrieve your old site content, however your new account will allow you to post the content using either FrontPage 2002 or earlier, or via FTP. The original message that was sent can be found Here
If you encounter any problems with this migration, please contact Adelphia Technical Support if you have questions.
So I says to him "Hey, Lama, hey, how about a little something, you know, for the effort, you know." And he says, "Oh, uh, there won't be any money, but when you die, on your deathbed, you will receive total consciousness." So I got that goin' for me, which is nice."
Old 09-23-2008, 02:59 AM
infoage1's Avatar
Originally Posted by Ducman851 View Post
Way to go Tom
Hum, worked fine when I posted it. Oh well, at least I tried to help
apfelbaum, I'm volunteering ducman851 to personally come over to your house to help.
Way to go John
Old 09-23-2008, 03:51 AM
Offer accepted, I was just about to get dirty again. However am willing to wait the 2,3 or 4 hours it might take to get here. Will have cold brews available if necessary . Yes, that was a fantastic page. But..begars can't be choosers. Haha, on a side note, I'm just going go with a number for the clearances that is in the middle and agrees with all the different numbers available for this motor.???
I'll be sure to turn things over real nice and slow before putting fire under it.
Old 09-23-2008, 05:35 AM
infoage1's Avatar
Here, try this:
Old 09-23-2008, 06:04 AM
LOL
Old 09-23-2008, 08:31 AM
Ben710's Avatar
That´s an awesome site, thanks for posting the link!
Old 09-23-2008, 11:45 PM
TrickLidz's Avatar
TrickLidz TrickLidz is offline
I use Bruce's info too!!
Old 09-30-2008, 03:07 PM
lrutt lrutt is offline
Might go with the MBP collets while you're in there. They will hold an adjustment much much longer than the split stock rings. All depends on how often you will ride I guess.
MY TOYS
2001 Ducati 'Il Mostro Cromo'
2001 Honda XR650L Dual Sport
1994 Harley Davidson Heritage
1978 Honda CB750K w/side car
1977 Moto Guzzi 850 LeMans Mk1
1976 Honda CB750K original
1973 Norton 850 Commando
1965 Honda 305 Dream restored
1971 Triumph Trophy 650
1970 Honda Trail 90 restored
1973 Honda Z50 rebuilt
2004 Harley Davidson Sporster 1200C
1984 Yamaha Virago 1000
1981 Honda Passport 70
