Featured Photos
by molasses
Member Galleries
2078 photos
644 comments
by dbenson
Member Galleries
2078 photos
644 comments
by afmbud
Member Galleries
2078 photos
644 comments
by ctx46
Member Galleries
2078 photos
644 comments
  #21 (permalink)
Old 09-19-2008, 11:22 PM
foggy123's Avatar
foggy123 foggy123 is offline
Originally Posted by ducxl View Post
Foggy123 said:
"Seattle Ducati is finishing the dual map tomorrow.
Pre lim numbers ~126hp/84torque
On their machine other models do this
996 108/74
1098 145/84
1098r 153/90 "
The 996 quoted above is a stock configuration right?
I'm trying to relate that stupendous 1080 engine to my own BCM Ducati 996 engine with ported heads,SPS cams,13:1 Pistals.
Of course,i can only speculate here but,i was told to expect somewhere in the mid 120HP range.THat 1080 dynoe'd at 126?
Something seems amiss...Or is the 1080 solely about increased torque?
Depends on the dyno. Seattle Ducati uses a Superflow while others use dynojet. They claim a 10% lower difference between them and dynojet.
Check out the 1098 vs 1080 graph. One has alot more low end and one more topend. Which do you think will be better for the street?
Speedzilla photogallery.
  #22 (permalink)
Old 09-20-2008, 03:40 PM
webman webman is offline
The dyno graph looks like you could have gone over 130 if you revved it out to 9.5-10,000 rpms. Does the longer stroke crank limit the redline that much or were you just being on the safe side?
  #23 (permalink)
Old 09-20-2008, 04:08 PM
foggy123's Avatar
Motor is still being broken in at the time of the dyno so revs were limited to 8500. Bruce told me to keep under 9500 my rev limiter is 10000.
  #24 (permalink)
Old 09-20-2008, 06:33 PM
desmo11's Avatar
desmo11 desmo11 is offline
10% between Superflow and DynoJet dynos?!
Ah, probably not.
Should be more like 2%.
One thing with DynoJet though, is you have to watch their corrections-- specifically that they aren't going bananas due to sensor placement or sensors being out of calibration. Really this goes for ANY dyno, but I've seen a few DynoJets with flaky atmospheric sensors.
  #25 (permalink)
Old 09-20-2008, 06:37 PM
erik996 erik996 is offline
I would be shocked if you had only mid 120hp range for that. I have the SPS cams and Pistals in my 996, with stock heads and I'm at 133hp/80ft.lbs. I would expect upper 130s with ported heads.
  #26 (permalink)
Old 09-30-2008, 10:16 PM
foggy123's Avatar
Update:
I picked the bike up today. Will be going on first ride soon.
Note dyno graphs are at 80% throttle position because FI is at 100% at that position right now. Will have to go back in and increase fuel pressure to get to the 100% throttle openings.
