Old 06-12-2006, 09:38 PM
DanST4's Avatar
DanST4 DanST4 is offline
Default STM Clutch Pushrod Pin (question)
Has anyone tried one of these?
"A small item that is a huge improvement over the original: the clutch pushrod pin is the part that fits into the clutch bearing and accepts the thrust of the clutch pushrod. STM's version is crafted of stainless steel and designed so the pushrod contacts a captured ball bearing for silky smooth action. The visible tip is laser engraved with the STM logo. Fits all Ducatis with dry clutch except Corse models - these need 044MG001R."
2001 ST4 Mod Rod
Old 06-12-2006, 11:32 PM
D998R's Avatar
D998R D998R is offline
It is NOT a huge improvement over the original. You would be hard pressed to notice any difference in a blind test.
Old 06-13-2006, 01:23 AM
CuStOm's Avatar
CuStOm CuStOm is offline
It would probably do a better job of keeping the rod from freezing up and taking the slave cylinder out.
2003 ST4S-ABS / 2006 S2R1k / 853 Track Junkie Toy - Limited S8SBK Self-Implosion Edition (Now uber better 998)
Old 06-13-2006, 01:59 AM
injected's Avatar
injected injected is offline
Send a message via Skype™ to injected
I don't think so. The bearing that this part sits in is what's important. I don't see what difference an extra 'bearing' (probably just one ball in the end of the hole) makes.
Old 06-08-2009, 10:14 PM
El Gladiateur El Gladiateur is offline
Old thread resurrection
Does anybody use this STM clutch pin?
Is it a direct swap part?
Old 06-08-2009, 10:52 PM
Ben710's Avatar
Ben710 Ben710 is offline
I see you have the same problem as I do. Donīt know how to waste your money properly, right?
powerwheelie racing weblog
Old 06-09-2009, 12:02 AM
TrickLidz's Avatar
TrickLidz TrickLidz is offline
lidzduc.blogspot.com
I've got the same problem....I think it's a Ducati thing!!!
http://www.speedzilla.com/forums/signaturepics/sigpic6094_1.gif2003 999R
1999 ST2
1998 748
2006 R1200RT
My Knols-http://knol.google.com/k/steve-methia/-/2rk7csiieinrp/0#knols
Old 06-09-2009, 04:58 AM
chill chill is offline
Ahem.
My name is Chill and I can't stop throwing money at my Duc.
Old 06-12-2009, 11:58 AM
Đ 2007, Speedzilla.com, Inc
