Featured Photos
by zen748
MotorbikeCafe
25 photos
9 comments
by henkieh
Member Galleries
2073 photos
644 comments
by advocatt
Member Galleries
2073 photos
644 comments
by aces anugal
Member Galleries
2073 photos
644 comments
Old 05-01-2006, 01:04 AM
Rico748's Avatar
Rico748 Rico748 is offline
Default STM full floating rotor button kits
I'm going to try the STM full floating rotor button kit from Lockhart Phillips.
I'm looking for ideas on removing the semi-floating buttons on the stock Brembo rotors.
1999 R6
2000 853
2006 1000DS
Old 05-01-2006, 01:45 AM
oneducs's Avatar
oneducs oneducs is offline
i have my rotors done with the STM buttons, and i used a 4 1/2 grinder. being very careful not to touch the carrier. it took about an hour or so to do, just be very careful that's all.
Old 05-01-2006, 01:48 AM
Tornado Tornado is offline
Grab the front of the existing buttons with a set of needle nose vice grips, then lay the rotor flat on a board (backside facing up) and drill out the button with a large bit. If you don't hold it when you drill it'll spin.
Old 05-01-2006, 01:51 AM
mental998's Avatar
mental998 mental998 is offline
I drilled mine out. You can do it with the wheel on the bike if you want.
Old 05-01-2006, 02:28 AM
infoage1's Avatar
infoage1 infoage1 is offline
I used a metal countersink, like you see inn the auction below, and a small pair of vise-grips to keep it from spinning. I think by using a countersink, there is less risk of having the bit jump out and digging into your carrier Either way, go slow...
http://cgi.ebay.com/3pc-TITANIUM-COUNTERSINK-DRILL-BIT-SET-1-2-5-8-3-4_W0QQitemZ6053694765QQcategoryZ50383QQcmdZViewIte m
Tom - S4 Foggy, 996R....
Old 05-01-2006, 09:09 PM
TrickLidz's Avatar
TrickLidz TrickLidz is offline
grinder!
BTW: Please apply a drop of epoxy on the retaining clips of the floating buttons after installing
Old 05-01-2006, 09:13 PM
TrickLidz's Avatar
ST2
Old 05-02-2006, 07:24 PM
DukeDesmo's Avatar
DukeDesmo DukeDesmo is offline
+1 on the Grinder, I tried drilling mine out but it was too much like hard work, I reckon it would have taken all day. Took me less than 1 hour with a grinder.
Wheel spins so much more freely now.
Old 05-02-2006, 07:49 PM
I tried the grinder at first, but the buttons got so damn hot I didn't want anything to warp.
Old 05-03-2006, 03:57 AM
jaymags jaymags is offline
Send a message via ICQ to jaymags Send a message via AIM to jaymags
Don't mean to hijack the thread, but a question for those of you with the floating buttons. Do your rotors rattle like a tambourine, and do they stick sometimes when you are backing the bike up? Just curious, cause mine do, but they work well.
Old 05-03-2006, 03:06 PM
Mine do exactly what you describe...I was a little concerned on the "backing" issue, but apparently it's a common issue with the full floaters.
Old 07-01-2006, 04:38 AM
BlondeDucati's Avatar
BlondeDucati BlondeDucati is offline
Default Worth it...
I asked this question after I installed my 19x18 radial m/c...
Did they make a difference????
I am still trying to figure out the benefit other than helping to reduce possible warping (which in itself is a good benefit....)
DC
I love my " Bikini Blonde "...
03 SS1000DS
76 Yamaha RD400C
Old 07-01-2006, 05:17 AM
infoage1's Avatar
The sole reason I swapped full-floating buttons in, was to help "reduce possible warping." I went through two pair of snowflakes before getting 998R narrow-band rotors in which I installed the buttons. Of course it could simply be the new rotors, but I have over 10,000 miles on them with no issues. Implied benefit enough, for me.
Back to your question...the little guys save a suprising amount of weight. I forget exactly how much, but I think is was around 12oz for the pair of rotors. It would have been more with the snowflakes, given they have more buttons than the 998R narrow-bands.
Old 10-05-2008, 03:01 PM
cuvi cuvi is offline
Default floating button
How many people have the replacement of the butons while the disks were still on? I would thinkg grinding or drilling would would cause metal to get where you dont want it to be.
Old 10-05-2008, 05:15 PM
Old Fart Old Fart is offline
Use an external snap ring pliers, stick it in the buttons, squeeze it and rotate the buttons 90 degrees. Works fine for a few months then do it again.
02 998 La Strega Bella
