The other day somebody stated that v2's make more torque, while i2's make more power - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Misc / Off Topic Area > General Auto Chat
Old 07-08-2009, 04:41 AM
PSk PSk is offline
Question The other day somebody stated that v2's make more torque, while i2's make more power
Why would that be?. Note this comment was not on this site ... another site.
Surely torque is a function of engine size, while power is a function of engine size and breathing (assuming they both can hold together at the desired rpm)?
Also a 90 degree v2 is better balanced than a inline 2 thus surely it could rev higher with lighter components (ie. casing holding it all together, etc).
Pete
'97 Suzuki GS500E
Grumpy Kiwi.
Old 08-31-2009, 05:48 PM
Default engine layout
I dont think thats a rule or anything. Many inline fours make a boatload of torque these days. If you take a v twin 1000 vs a 1000 inline 4 you have the potential for more torque with the twin, because you will have to have a much longer stroke and 2 larger bores, which I think helps in the torque aspect. where in the 4 cylinder the displacement is split up into shorter stroke, and 4 smaller bores which can rev much higher to help with horse power. with a v twin vs i twin configuration at the same displacement, if the bore and stroke are the same then it would come down to a lot of other factors like overall engine efficiency. I dont think the v or inline configuration would matter at all.
Old 09-02-2009, 04:52 AM
Can Afford To Be Critical
Pete
Torque is a function of displacement, valve area, and cam timing. Period. Power is a function of this plus rpm.
