Anybody retarded ignition timing...? - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Manufacturers > Ducati - The workbench
Old 01-30-2007, 08:26 PM
Default Anybody retarded ignition timing...?
..and would be willing to post a brief tutorial? I need to do this (actually, on a 97 900SS) in conjunction with installing high-compression pistons. Thanks - BrianK
Old 01-31-2007, 01:36 PM
jhord's Avatar
The ignition pickups are located on a moveable plate under the left sidecover. The plate has graduated lines on it, each being ~2 degrees. Simply loosen the nuts on the plate, move to the desired setting, and tighten. The air gap should be .6-.8mm.
Soon I will start work on a programmable CDI for the carbed 2v's. Then none of this plate-moving stuff will have to be done, you can change timing from a laptop. It will have a shift light, shift kill, available TPS input, and adjustable rev limiter, all built in. It will probably be a couple months until it is done, however.
Old 01-31-2007, 02:58 PM
bruntr's Avatar
I like the sound of this.....very interesting! Please keep us posted
Current rides
1993 966SS animal
1987 700 Suzuki Intruder
Old 01-31-2007, 03:26 PM
Thanks. Which way do you move the pickups to retard timing?
Old 01-31-2007, 06:24 PM
jhord's Avatar
Counterclockwise when looking at the flywheel.
Old 01-31-2007, 06:25 PM
marvin's Avatar
I just cut a couple mm's off of the front side of the timing "bump" on the flywheel. this retarded the full advance timing a couple of degrees but left the "idle" timing stock. Makes for better slow speed and idle.
Old 01-31-2007, 06:40 PM
Thanks folks!
Old 02-03-2007, 09:47 PM
jhord's Avatar
Well, as of this afternoon the prototype is up and running successfully!
Old 02-03-2007, 09:53 PM
marvin's Avatar
Thumbs up
Very Cool !!!
Old 02-03-2007, 10:08 PM
Cutaway's Avatar
Default Not to hijack....
Mr. Hord,
Not to hijack this thread too bad....BUT can this system be used for an RC51? I have a PCIII USB & I know Power Commander has their ignition module, BUT according to their website it's a "NO GO" for the RC. Thank you!
Josh
You may now all return to your regular scheduled DUCATI programing
www.speedcell.org
www.durbahn-usa.com
Good luck is for novices, bad luck is for everyone. Rely on your skills.....You control em!
Old 02-04-2007, 12:16 AM
jhord's Avatar
Nope, sorry.
Old 02-06-2007, 07:31 AM
Cutaway's Avatar
Default opps
Thanks Hord.. & I just re-read your post that it was for carbed 2v I think I have ADD.
www.speedcell.org
www.durbahn-usa.com
