exhaust backfiring! - Speedzilla Motorcycle Message Forums
Old 09-15-2005, 09:46 PM
kapman42's Avatar
Send a message via Yahoo to kapman42
Question exhaust backfiring!
I replaced my cans with CF slip ons, with a Hot Jet coated stock header, I hooked the whole thing up. Now it sounds great!!
The problem is when I let off gas, the cans backfire! I know I used the exsisting header gaskets (a no no), but could not find any locally. I have a small exhaust leak on back cyclinder, but will re seat the header and gaskets to see if that is the cause. Does anyone else know why it is doing this? Do I need to correct the jets with new slip ons?? It has stage 1 kit already on it.??
Any advise would be appreciated...
USAF Rules!!!!!
95 900SS CR
Old 09-15-2005, 10:40 PM
Nick D.'s Avatar
Try having someone put their hands over the endcaps of the cans while you quickly check the exhaust for leaks. If it wasn't backfiring before it shouldn't now if it was jetted properly. I have re-used stock exhaust gaskets with no issue.
2000 M900 i.e.
Old 09-15-2005, 11:11 PM
edwyun's Avatar
what kinda bike? and did you go from the OEM cans to the slipons?
Ride safe,
Edward
Ducati '72 750GT (#751379)
Ducati '98 900SS/FE (#231)
IBA #18798
Old 09-15-2005, 11:27 PM
DesmoDog's Avatar
Originally Posted by kapman42
...I have a small exhaust leak on back cylinder...
Fix the leak before you get too carried away worrying about other things. Leaks can and do cause backfires on decel.
-Craig
Team YIKES! Motorsports
Old 09-16-2005, 02:05 AM
kapman42's Avatar
Talking RE; backfiring..
Replaced staock aluminum cans for no name Carbon Fiber Slip ons.. Got them from Wounded Duc. Did not see a name on them..
I will re check for leaks around cylinders...
The gaskets are all rusted, so worried that it could cause the leak by not sealing..
Thanks for the advise..
USAF Rules!!!!!
95 900SS CR
Old 09-16-2005, 02:08 AM
edwyun's Avatar
+1
And with aftermarket slipons, you may need to rejet the carbs/ or adjust the FI, especially if you have an open/vented aribox mod as well.
Ride safe,
Edward
IBA #18798
Old 09-16-2005, 03:22 AM
DesmoBob's Avatar
Fueling adjustment, probably.
