pc5 - Speedzilla Motorcycle Message Forums
Old 04-25-2010, 08:57 PM
chris steedman's Avatar
Default pc5
The power commander 5 is installed with the dual autotune kit on my 749 . There are some serious TPS issues to the custom install which stops any mapping process . Its a simple one wire fix with some knowledge involving digital earth . The target airfuel is selected at all throttle postions with 250rpm increments manually. Once set the bike very quickly adjusts the air/fuel automatically . A map can then be built and after each ride a reccomended trim table appears to fine tune a map or leave it in autotune mode and just ride. The smoothness is amazing and the bike no longer stalls. Gears and load can be programed so the air fuel is optimised for any gear any speed. The auto tune accounts for any tuning work .Shame they dont make them to fit ducatis out of the box...lol... . The next step is to try and fit the ignition modual (obv not from a ducati).
life is work
www.hypertrick.net
www.bikeboy.org
Old 04-29-2010, 09:56 AM
oops posted in wrong section . Should have been superbikes . Mod - please remove.
life is work
www.hypertrick.net
www.bikeboy.org
