212 grind cams inconsistant - Speedzilla Motorcycle Message Forums
Old 02-10-2010, 07:09 PM
chris steedman's Avatar
Default 212 grind cams inconsistant
I degreed some v2 212 cams today . The advertised duration is 265 so i was expecting to see 259 or so with 0.10mm clearances . However one cam showed 272 and the other showed 276 WTF !!!
With my desired LC one cam is closing way later and opening earlier . I have had similar stuff happen from time to time but not this much. The LC is now what it is but lef wondering about setting cams using other methords instead of LC
life is work
www.hypertrick.net
www.bikeboy.org
Old 02-13-2010, 08:17 PM
vij vij is offline
www.virdung.net
I did some v2-211 for a friend a few years ago and i got 263/238 (forward), 255,5/238 (rear) duration. Should be 267/236. I was a but surpriced with the big difference between the cams. The difference in LC (in/ex) was about 2 degrees between the cams so it was not so bad.
Jocke.........
MHR 900 1984
S4 984 2002
www.virdung.net
Old 02-19-2010, 02:16 PM
Jocke.........
That is not good really . One pot may make more power than the other . Veetwo has gone now havent they ?
life is work
www.hypertrick.net
www.bikeboy.org
Old 02-19-2010, 09:12 PM
redtop's Avatar
I friend of mine has V2 cams in his M900ie. He had a hard time setting the valve clearence since the cams base circle differs as much as 0,20 mm !!!
So I'm not surpriced that you measure inconsistant duration.
/RedTop
http://bimota-db2.blogspot.com/
Old 02-20-2010, 08:10 AM
vij vij is offline
www.virdung.net
I am a bit surpriced. I thought that vee two were good stuff.
Jocke..........
MHR 900 1984
S4 984 2002
www.virdung.net
