900 supersport head interchange options - Speedzilla Motorcycle Message Forums
Old 01-18-2010, 04:18 PM
Default 900 supersport head interchange options
Sorry for the newbe question, but I normally work on the 4 valve bikes. I have a customer that droped an intake valve on the vertical cylinder on his '99 900 SS. In the process it killed the cylinder head and piston. which heads if any interchange with the 900 SS? I did the search and did not find anything usefull. Any assistance would be greatly appreciated.
Old 01-22-2010, 11:48 AM
chris steedman's Avatar
Any 900 monster ss carb or injected will fit . Some of the old early monsters had small valve heads. Heads you want have the V2 stamp.
life is work
www.hypertrick.net
www.bikeboy.org
Old 01-31-2010, 11:35 PM
Don't forget the external oil lines of the pre-98 bikes. The 900ss ie are reported to have bigger cams simillar to the ST2
www.hoosierhooligans.org
