Top Power from 900SS - Speedzilla Motorcycle Message Forums
Old 06-10-2009, 09:25 PM
Smile Top Power from 900SS
I'd like to thank Chris Steedman for his help in getting 97.2 BHP and 65lbdft of torque from my 900SS I.E. Without doubt his headwork has made it happen.
Thanks also go to Mark Hill at MHP for the fantastic job he made on the exhaust. The underseat system is the mutts nuts and definitely helps the motor breath while sounding and looking awesome.
If only we'd moved the rev limit to 9500 we would have made a ton.
We don't know if this is the best figures from a UK 900 but they must be close.
Old 06-10-2009, 11:04 PM
chris steedman's Avatar
And i think we better thank Tim Blakemore for mapping it and Rich llewellyn for saving you a 250 mile trip by having a pc3 in stock when no main dealership within 100 miles of Bristol did Well done guys
life is work
www.hypertrick.net
www.bikeboy.org
Old 06-11-2009, 01:26 AM
dansamp's Avatar
any photos ??
Old 06-11-2009, 08:49 AM
Default Photos
There will be some as soon as i've worked out how to post them up.
Old 06-11-2009, 08:52 AM
Default Thanks again for the power
Yes Chris, indeed this was a team effort. It proves that if you get the right people involved you get good results.
Old 06-11-2009, 04:54 PM
Default Some pics of my 900SS
Hi Guys, please find a couple of pics. Sorry about the quality but I had to save them as .GIF's. I think you'll get the idea though.
Old 06-11-2009, 04:59 PM
Default More pics
Here's a couple more.
Old 06-14-2009, 03:48 AM
does it have a midrange dip?
Brad The Bike Boy
www.bikeboy.org
Old 06-14-2009, 11:24 AM
Default Brad
The print out is just one smooth unbroken line - ill have the run files next week . You want them ?
life is work
www.hypertrick.net
www.bikeboy.org
Old 06-16-2009, 12:01 PM
sure.
Brad The Bike Boy
www.bikeboy.org
Old 06-16-2009, 06:05 PM
CrimsonCloak's Avatar
Now that is a fine looking machine.
Old 06-17-2009, 09:43 AM
TomTom's Avatar
Nice going Chris!
On the subject, I was involved in a 1000ss with ported heads by Proservice (reshaped intake) and DP cams but stock pistons and it didnt get the dip at 7k either as usually follows with DP cams and stock heads. Too bad there wasnt room for a good set of pistons in the budget.
Luckily I ran it prior to the mods and mapped it properly and then after mods again and the result goes like this:
Old 06-22-2009, 03:47 AM
bruntr's Avatar
Boy is that nice...great work
Here is my dyno sheet after my 966 build.... you can make power with these air cooled motors and surprise quite a few rice burners in the process
Current rides
1993 966SS animal
1987 700 Suzuki Intruder
Old 06-22-2009, 02:29 PM
sburns2421's Avatar
Desmolicious
Cheating, but find one of these kits...
DucCutters: PCS Turbo Kit (Mike Lee)
Old 07-06-2009, 02:36 PM
Default Top Power from 900SS
Hi Guys,
Here is the power curve and a pictiure of the beast.
One tip though - remeber to change the clutch actiation rod bearing when you rebuilt the motor - I didn't and OUCH!
Old 07-17-2009, 05:09 PM
Default Power from 900
Hello.
I have a 1996 900SS and am considering the 966 Kit...Could you tell me what else had to be done to make the change??
I am looking to purchase this fall and install after ridiing season...which for me in SE Mi. will be Oct-Nov..
By the way...beautiful beautiful bike.
MIke S
Old 07-18-2009, 10:48 PM
Mike, you should check out Chris Kelley's site at ca-cycleworks.com or ducatitech.com. He seems to be able to get more than 100 hp out of carbed pre-1999 Supersports. Benno1803's is fuel injected.
Joe
Old 07-20-2009, 05:47 PM
Joe
Bennos doesnt have a big bore kit - its just a 900. It also uses stock valves not large ones. Add a 966 big bore kit and some oversize valves to bennos then it will be way over 100hp
Top end wise there is not much in it between well set up short manifold carbs and fuel injection.
life is work
www.hypertrick.net
www.bikeboy.org
Old 07-21-2009, 01:56 PM
FunkZ's Avatar
Injection is for addicts
So what all was done, just the heads and a remap?
Benno I am also trying to figure out what frame that is. Obviously it's the 9x6-style bodywork but what has the bolt-on solo rear with the 900ss tank?
1995 Ducati 900SS
funkz.net/ducati
Old 07-24-2009, 12:27 AM
It had a balanced crank/flywheel with 900cc je pistons . Benno set his own squish and cam timing . I made the heads using the flow bench and modified but stock size valves . Then it was mapped with a pc3
life is work
www.hypertrick.net
www.bikeboy.org
