rev counter - Speedzilla Motorcycle Message Forums
Old 02-23-2009, 03:32 PM
Send a message via AIM to mortoduc
Default rev counter
Looking for direction, the rev counter has given up and the cable is turning in the drive off of the head is it more likely the cable or is the drive worn, has anyone else experienced this?
Paul
92,851
98,900SSFE
98,MZskorpion
Old 02-23-2009, 06:03 PM
StreetScrambler's Avatar
Yes, in 30,000 miles on my ’95 SS-SP, I am on my second tach cable, and third speedo cable. I don’t know if it’s the routing, heat, or just crappy cable construction, but they don’t seem to last long. I am guessing your problem is likely the cable. If you get a new cable I would suggest that you wash out the factory graphite (or whatever they use) and use an aftermarket cable lube or light motor oil. I’ve been using synthetic 10W30 in my latest speedo cable for a few years now. Fingers crossed.
My blogs and reviews:
www.StreetScrambler.com
www.EnvironMoto.com
In the garage:
2008 Triumph Street Triple
2003 Honda RC51
1995 Ducati 900SS SP
1984 Honda XL350R
1975 Yamaha RD350
Old 02-25-2009, 02:43 AM
Mine has just died as well ,apparently this will be the second cable in 25 000 KM ( 15 500 miles)
Old 02-26-2009, 06:58 PM
my FE has 53k on it and this was the second time this has happened. it appears that the cable has some wear at the drive end. I took the cheap was out and shimmed it and it works fine now.
Paul
92,851
98,900SSFE
98,MZskorpion
