Wiring Woes - Speedzilla Motorcycle Message Forums
Old 10-17-2008, 04:28 PM
Send a message via AIM to mary2al
Default Wiring Woes
My 96 900 SS SP -- Everything has been working perfectly till last night the headlight went off twice. The fuse box was very hot and the coils were very warm. I had not been riding hard or long. Any ideas?
Thanks,
Al
Old 10-17-2008, 06:36 PM
Have you checked the regulator an his wiring?
Old 10-18-2008, 04:14 PM
FunkZ's Avatar
Injection is for addicts
Do you have a bulb with a higher watt high beam? Had the same thing happen to mine, was running a 55/100 I believe and it overheated and melted the headlight wiring harness. Had to splice on a new one and went back to the stock bulb.
1995 Ducati 900SS
funkz.net/ducati
Old 03-04-2009, 12:31 AM
FIRST check battery cable connections - clean and tight?
probably not that but it's the very first thing to check. save you a lot of trouble if that's all it is. BTDT.
Old 03-17-2009, 05:20 AM
Goldmember
Try cleaning your grounds and terminals. Something is drawing a lot of current to make your fuse box get hot. Does your headlight blow the fuse? Is the correct fuse installed? Do your lights get significantly brighter as you rev your engine? If so, it is probably the voltage regulator. Just start probing it all over with a voltmeter looking for the voltage drop. Check out the Haynes maintenance manual. Hope this helps!
'94 900 SS SP #59
