Featured Photos
by ajonty
Member Galleries
2078 photos
644 comments
by Jeff H.
Member Galleries
2078 photos
644 comments
by C. Dolan
Bike Pics
83 photos
44 comments
by nycstripes
Member Galleries
2078 photos
644 comments
Old 09-05-2008, 12:53 AM
BrianK BrianK is offline
Default Broken ring, scored cylinder
Digging into the 1997 900SS to see why it's burning oil.
Not too hard to figure out - pulled the horizontal cylinder (that's the one that was low on compression and oil-fouling plugs) and I find a broken oil ring and a scored cylinder - nice little symmetrical "column" of discolored metal that I can feel, slightly, with a fingertip.
Can these cylinders be rebored? Any idea how much that should cost? Do you then need oversized rings?
This is no doubt a self-inflicted wound....
Thanks all - BrianK
Old 09-05-2008, 04:45 AM
Ducman851 Ducman851 is offline
Time for a 944 kit.
Send em to Millenium Technologies with some new pistons and have them bored and replated.
So I says to him "Hey, Lama, hey, how about a little something, you know, for the effort, you know." And he says, "Oh, uh, there won't be any money, but when you die, on your deathbed, you will receive total consciousness." So I got that goin' for me, which is nice."
Old 09-05-2008, 12:25 PM
Thanks Ducman, but the thing has relatively new 11:1 stock bore pistons in it now - it was probably during the install that I screwed up a ring without noticing it (had a couple of "redo's" and probably lost patience and began rushing things....FCRs, lightened flywheel, DynaCoils - plenty o' power already. I really don't want to invest that much more in it. Thanks - Brian
Old 09-06-2008, 12:15 AM
motoxxx79 motoxxx79 is offline
probably be cheaper to find a new used set, or to pick up a used 900 motor. boring and replating nikisil cylinders is expensive
Old 09-06-2008, 06:16 AM
jmmmrm's Avatar
jmmmrm jmmmrm is offline
I will be hopefully sending my cylinders off to millenium in the next month. You can see my previous threads about getting a group buy for custum pistons. I ended up going in with Guy and ordered 10 sets of the 95mm pistons (whould be done at the end of the month). I have 10 sets of cylinders that I will be getting bored and plated. Millenium is going to give me a price break for that qnty, so if you just want a plating, that should not be an issue. Call them for a price quote and then I can get a quote from them for an additional cylinder just for the plating/honing. Once I get all set, I will be posting the kits.
Mike
Old 09-20-2008, 04:05 AM
Mike, thanks. I was able to buy a used cylinder off another member and installed it today. So far, so guuuuuuuddddd! Thanks - BrianK
