Old 09-02-2008, 12:33 AM
Multitard Multitard is offline
Default broken case, need opinions....
a friend was riding and the chain came off, didn't break, but sheared the case and alt cover. What do you think I should do with this?
2000 795cc Supersport
Old 09-03-2008, 01:53 AM
motoxxx79 motoxxx79 is offline
Find a talented welder and have them TIG it. Should be able to fix both parts, but it may be cheaper to replace the left case cover than fix it (ebay) unless time is a factor.
Old 09-03-2008, 03:11 AM
superleggera's Avatar
superleggera superleggera is offline
Look at eBay and get another sidecase cover -- $35-$100. It will cost more than that to weld it and then clean up the cosmetics and mating surface itself.
Case itself -- strip paint around the area, clean and remove all oil and TIG weld up as required. Then cleanup the mating surface. Depending upon the weld itself, you could be able to cleanup the external weld itself and then lightly dimple to emulate cast surface. Paint as desired.
me: Mark Savory play: www.MarkSavory.comwork: www.MotoCreations.com
Old 09-03-2008, 10:41 PM
foggy123's Avatar
foggy123 foggy123 is offline
Repairable yes but why not just upgrade to a 900 motor?
Speedzilla photogallery.
Old 09-03-2008, 11:22 PM
haven't updated my sig in a while, it's a 900SS, so it's a 904
