Engine Noise
My '99 750ss with 16K miles has been sitting since last fall, needing a bit of work (valves adjusted, new belts, front tire, sprockets, etc.). After triple checking the valve clearances, only the vertical cylinder's exhaust shim required removal/adjustment. Now, after changing the belts, oil, and spark plugs, I finally fired her up, only to hear a fairly loud and distressing metal against metal tapping sound seemingly originating from the front/horizontal cylinder area. The taps increase when the throttle is opened. I started it up a few times, thinking perhaps the new oil hadn't yet circulated well, but the tapping hasn't much abated. Thus far all I've done is check the spark plug gap and remove the horizontal cylinder's valve covers, and all seems well (I never removed any clips or shims from this cylinder).
Any ideas about what to check next would be appreciated.
Also, when reinstalling the front tire I forgot to remember to remind myself how the speedometer cable is routed. What keeps the cable from touching/lodging against the rotor?
