Featured Photos
by zippy
Member Galleries
2073 photos
644 comments
by juicedstang999
Member Galleries
2073 photos
644 comments
by jwm2k3
track photos
10 photos
0 comments
by jazz
Member Galleries
2073 photos
644 comments
Old 05-05-2008, 02:06 AM
FunkZ's Avatar
FunkZ FunkZ is offline
Injection is for addicts
Default Fuel cap gasket replacement
When I placed my order for the clutch pushrod seal set at Desmo Times I also picked up a new set of battery straps and a fuel cap gasket as mine are cracking pretty badly.
For the battery straps it looks like I'll need to remove the airbox/battery tray piece to install those from underneath? Doesn't look like they're meant to install from the top but just wanted to make sure before I go ripping all that out of there.
Also, on the cap gasket, I removed the cap and inner ring, removed the 8 small set screws around the lip, but the outer ring doesn't want to come off. Is it glued on or is there something else I'm missing holding it to the tank?
1995 Ducati 900SS
funkz.net/ducati
Old 05-09-2008, 12:07 AM
ThisEndUp's Avatar
ThisEndUp ThisEndUp is offline
You need to whack that sucker.
I used a smaller rubber mallet which fit inside tank hole...and pulled up on it (hitting it from within) going around and around until it popped out.
But first, you did take out those little set screws, yes?
'95 Ducati 900 SS/CR
'04 Aprilia RSVR Factory
'98 Yamaha FZR600R
'75 Yamaha RD350 (track bike)
'73 Suzuki T500R (track bike)
Old 05-09-2008, 12:55 AM
marvin's Avatar
marvin marvin is offline
Sometimes they stick pretty tightly!! Once you get it out apply a coating of grease to the tank and the green O-ring for next time!!
Old 05-09-2008, 06:22 AM
john S. john S. is offline
lotta white grease
2005 Honda 600RR (totalled)
2001 Ducati 900SS (sold-shoulda kept it)
1995 Ducati 916
2004 Ducati 999S
www.ducati-owners-group.com
Old 05-11-2008, 05:03 PM
FunkZ's Avatar
Thanks I will try beating on it some more, I was afraid to put too much pressure on it in case there was something else I was missing.
1995 Ducati 900SS
funkz.net/ducati
Old 07-19-2008, 03:34 AM
FunkZ's Avatar
Well, finally got around to trying this again. I was determined it was coming off there this time!
1995 Ducati 900SS
funkz.net/ducati
