Custom Spaghetti's with sound clips - Speedzilla Motorcycle Message Forums
Old 08-28-2005, 03:26 AM
Default Custom Spaghetti's with sound clips
Here's my page about the custom spaghetti's with sound
clips!
http://www.geocities.com/edwyun/spaghetti.html
enjoy
Old 08-28-2005, 06:30 AM
Default Re: Custom Spaghetti's with sound clips (edwyun)
Oh, man, why'd you have to post that? Luscious...I actually got goosebumps. So, can I talk you into sharing your investment? And (not that it matters after hearing it) what kinds of gains did you see on the dyno?
Old 08-28-2005, 06:36 AM
Awesome! He does beautiful work!
Old 08-28-2005, 02:46 PM
Default Re: (SS900FE)
Very nice pipe work. I think your bike sounds better than most superbikes.
Is your bike stock color? I thought all FEs were silver.
Old 08-28-2005, 05:09 PM
Default Re: Custom Spaghetti's with sound clips (DesmoBob)
Thanks all.
I did dyno the system, but due to high humidity, the numbers are a bit suspect. Plus, I installed the dual FCR's at the same time and only got to dyno the low mount system, which apparently doesn't flow as much as the high mounts. Even so, I got about 4hp. Will be doing a another dyno with both low and high mounts soon.
Old 08-28-2005, 05:10 PM
Default Re: (corse955)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corse955 &raquo;</TD></TR><TR><TD CLASS="quote">Very nice pipe work. I think your bike sounds better than most superbikes.
Is your bike stock color? I thought all FEs were silver.</TD></TR></TABLE>
At 3000rpm, the sound meter read 104dB.
Yeah, all FE's are silver but I like the red better.
Old 08-29-2005, 12:21 AM
Default Re: (edwyun)
Hey Edwyun, guess what you STINK
I only wish mine sounded like that!!!
Old 08-29-2005, 01:27 AM
Default Re: (Dutch900)
Well, it goes like STINK too!
Old 08-29-2005, 06:10 PM
someone please hand me a tissue...
Awesome.
Old 09-11-2005, 12:08 AM
edwyun's Avatar
Dynoed the system and here are the results (all in SAE, although the dynos are taken on different dynos and of course on different dates):
BEFORE: OEM Mikuni carbs, Dynojet stage II, BMC airfilter with perforated airbox cover, 944HC Pistal pistons, BCM mild head porting, lightened flywheel, OEM headers, Termi slipons, = 82.1 HP and 68.5 ft-lbs torque.
AFTER: same as above but with 41mm FCR's and the custom spaghetti's = 85.8 HP and 75.1 ft-lbs torque.
Deltas: +3.7HP and 6.6ft-lbs torque.
But what you can't see in these numbers is that with the spaghetti's/FCR's, the "brickwall" that the 2V engine hits above 7500 RPM is much less and HP tapers off less.
Nice for a non-SSie 2Vduc.
Ride safe,
Edward
Ducati '72 750GT (#751379)
Ducati '98 900SS/FE (#231)
IBA #18798
Old 09-20-2005, 05:04 PM
Location: R.P.V. California, U.S.A., R.P.V. California, U.S.A.
Edward, I have to know how $$$ for the complete system w/high cans?
Old 09-21-2005, 12:50 AM
edwyun's Avatar
I think the exact cost depends on the cost of materials - contact Doug at ARC Fabrication at srrenn@metrocast.net or call BCM.
But, it is much much less than the approx. $3000 USD Termi wants for their full spaghetti system.
Ride safe,
Edward
IBA #18798
