I have an Acid problem... - Speedzilla Motorcycle Message Forums
Old 08-13-2005, 06:06 PM
Default I have an Acid problem...
So, as the bike was cartwheeling through the graveltrap, fuel tank torn loose and flapping around, the battery [prior to, and during, it's ultimate ejection from the bike] sprayed a fair bit of acid all over the harness, relays, ecu, etc.
Question: Is there an easy way to neutralize the acid, short of squirting a baking soda solution all over everything, and then hosing it all off? I'm not big on the idea of seriously soaking everything.
Will misting it all with WD-40, and wiping it down, neutralize acid? [it seems to have so many other uses]
Or is there something else out there that will accomplish this?
Thanks in advance for all your tips/advice
Old 08-15-2005, 02:05 AM
I would do the baking soda and rinse with a lot of destilled water. Do it as SOON as you can.
Old 08-15-2005, 01:16 PM
Default Re: (NC Rick)
Will do. Thanks.
