Cruise Control - Speedzilla Motorcycle Message Forums
Old 05-31-2005, 10:09 PM
Default Cruise Control
Other than the trottle rocker, does anyone use anything else for a cruise control? I just called Throttle Meister and talked to some dude. They have their product for just about everything but an '04 1000SS. Anyone know if the bar ends are the same circumference on all Ducati's. More appropriately, what model will match an '04 1000DS?
Old 06-01-2005, 12:41 AM
Default Re: Cruise Control (DocThee)
Yeah, it's called your fast idle. All that does is open the throttle plate some. Adjust it so there is next to no slack in the line and you can use it as a cruise control. Mine will hold the bike at 80-85 when set wide open in top gear.....It's not a choke....
I use it to rest my hand and when cruising on the freeway for long extended periods.....You don't need to buy anything, YOU HAVE ONE!
Old 06-02-2005, 01:38 AM
Wow, crusie control on a motorcycle, that sounds dangerous...But tell me more, will it work on my 2001 750 sport?
Old 06-02-2005, 01:46 PM
Default Re: (Ageispolis)
You only use it to give your hand a break. I only use mine on freeway long hauls....It is not intended to be done for alot of time, just long enough to relax the hand and wrist some.
Your fast idle is nothing more than a "mini throttle". It hold the throttle plates open to a specific place to allow the bike to warm up without flooding it if you use the throttle only. It is not a choke. Often it is referred to as an enrichner. If you follow the cable off of it you'll see it connect to the throttle butterfly and opens it slightly when you pull it down. Same on the Aprilia's.
There is alot of slack in the line, adjust the slack out some and you can use it as a cruise control. I like it better than a Throttlemeister type device because it is on the opposite handlebar and is operated by just your thumb. The throttlemeister can be a drag to set and release sometimes compared to using the fast idle control as you have to use your whole right hand to set it and muck with it some to get it where you want it. I have also seen problems with Throttlemeisters when not set up correctly.
By using the fast idle control, it is seemless and you don't have that drop in speed while to set and/or release the throttlemeister. Simply hold the gas, engage the fast idle to the same speed with your left hand and go. The to release, grab the throttle and use your left thimb to turn off the fast idle control...
Old 06-02-2005, 07:56 PM
Why didnt I think of that before? I did follow the fast Idle cable to see that it is just another cable that pushesthe throttle open. But I didnt think to adjust it to get a cruise control effect. Can you still use it as a choke though? I mean what do you do in the cold weather?
