Turn Signal Holes: How do you cover them? - Speedzilla Motorcycle Message Forums
Old 05-27-2005, 02:01 AM
Default Turn Signal Holes: How do you cover them?
We're looking at the mirrors Dave is selling in his Group Purchase post, and they have the turn signals built into them.
Does anyone know if someone makes a kit to block off the original holes in the fairing? Any other ideas?
Old 05-27-2005, 12:15 PM
Default Re: Turn Signal Holes: How do you cover them? (AZ Scott)
Edit: Nevermind. I found something to block off the mirror holes, not the turn signal holes (for those who decide to mount bar end mirrors).
Old 05-27-2005, 01:24 PM
If you can't find anything you could always slap some bondo in the hole, sand it flat with the rest of the panel and repaint. Or some race plastic?
Old 05-27-2005, 02:08 PM
Vinyl that matches your paint? might look tacky unless you get some nice thin stuff.
Old 05-27-2005, 04:06 PM
Default Re: Turn Signal Holes: How do you cover them? (jager)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jager &raquo;</TD></TR><TR><TD CLASS="quote">If you can't find anything you could always slap some bondo in the hole, sand it flat with the rest of the panel and repaint. Or some race plastic?</TD></TR></TABLE>
Don't use Bondo.
Any fiberglass repair outfit would be able to cover the holes easy enough, or you could try it yourself. Then find someone with an airbrush to paint the spot.
You could make your own block off plate, cut a template and take it to a machine shop.
Or, just get some flushmounts and use 'em as running lights.
Old 05-27-2005, 06:57 PM
Default Re: Turn Signal Holes: How do you cover them? (Red)
I had the same concern which led me to not get the mirrors. Interested if anyone comes up with a solution. I like the running light idea but am just not there yet.
Old 05-27-2005, 08:18 PM
Default Re: Turn Signal Holes: How do you cover them? (Kennedy)
I had Morse Fiberglass shave the stock turn signal recesses on my body panels so I could use a set of smaller flush-mounts. They did this as part of the repair/repaint work I had them do following a low-side last year. Came out very nicely. I'm sure most body shops could do something similar.
Old 05-27-2005, 10:17 PM
Default Re: Turn Signal Holes: How do you cover them? (jpuck91)
cut a reflector to fit in the the gap....extra visibility from the side...
Old 05-28-2005, 06:52 PM
Well, we went ahead and ordered the mirror/signals. We'll figure out something with the fairing holes.
This is for Jessica's bike, and she doesn't want to get involved with all kinds of filling/sanding/painting. We just figured if there was some quick and easy piece, we would try that.
I kind of like the idea of using some flush-mount turn signals as running lights, but the hole/slot that the stockers bolt into is kind of odd-shaped. Hopefully, we can find a decent looking flush mount that will cover the whole area. Probably something with a dark lens wouldn't look too bad...
Old 05-28-2005, 08:27 PM
I bought some led pieces that had 4 LED's in them and was shaped that fit in the recess on my APrilia really well. It is not much different that the space on the Duc panels. You could use those as running lights. I plan to just leave them open for now, doesn't look bad or you could connect the LED blinkers with the mirror blinkers kinda like on the Audi's and Jetta's so you have blinking light on the side view and from in front (Mirror blinker).
The LED's take next to no power so they would run in line with the mirrors quite easy.
Old 05-28-2005, 11:39 PM
Default Re: Turn Signal Holes: How do you cover them? (bill900)
Where did you get these LED pieces? That sounds like a cool idea...
Old 05-29-2005, 10:37 PM
I'll have to find where I got them and let you know. I still have set over at my apartment I haven't used yet and won't be there till tuesday. I'll let you know. The ones I have, have a sticky back so you could just run the wires through the holes and press fit/stick them on to fill up the space. I'll try to remember to take the camera and take a pic for ya.
Should have something posted up by mid day tuesday. Hell I guess I'll use them for that too now! Forgot all about them till I read your thread! I bought a set of the mirrors and just replaced the stock back blinkers with a set of the micro arrow blinkers.....Looks sweet!
Old 06-03-2005, 08:55 AM
Bill,
Did you get a chance to find those LED's? Any pics? I found some nice ones but they are 1/4" too wide to fit in the recess.
