Old 05-19-2005, 03:21 PM
Default Fender Eliminator for the SS
If anyone wants a template for a fender eliminator, I have one. I bought one that has provisions for the blinkers and you can transfer the stock license plate light over to it. Only thing is it is plastic, so I traced it on paper and will re-make it outta aluminum and have it powdercoated. If anyone wants the pattern, drop me an email and I'll send it to you. I scanned it into a pdf and it is to scale. I also will include a powerpoint file that shows a side view of what it looks like when bent up into shape.
Old 05-19-2005, 10:57 PM
Default Re: Fender Eliminator for the SS (bill900)
i took off the fender and zip-tied the license plate to the frame. cost ~ guess the brake light conversion was a little more, though.
Old 05-19-2005, 11:06 PM
Default Re: Fender Eliminator for the SS (quickdraw)
yeah, I need to be able to run blinkers and a tag light for the inspections, butit is clean lookinf and with the mini arrow blinkers, looks trick....
Old 05-19-2005, 11:23 PM
I would like one. bro_dog at excite.com
Gracias.
Old 05-20-2005, 02:55 AM
Default Re: Fender Eliminator for the SS (toolfan)
I uploaded it to Ducati.MS
Go here and you can get it....The pdf is the template and the jpg file is a side view of what it should look like after you bend it up. The jpg file is actually a PPT file that I had to rename as a .jpg to be able to upload it. So just rename the .jpg file a .ppt after you download it.
http://www.ducati.ms/ubbthread...5&o=0
