steering damper clamps - Speedzilla Motorcycle Message Forums
Old 05-02-2005, 04:53 PM
Default steering damper clamps
I am installing a sprint 140mm steering damper as a side mount on my 03 800ss. I had trouble finding the rite clamps to mount the thing but finally found out that the front mounted on the left fork tube at 50mm and the rear??? I eye balled it next to a metric ruler at 20mm, couldn't find a mertic micrometer anywhere. Street and Comp only carry a 22mm and 25mm so I figure the 22 was right. Anyone know for sure what size clamp you need for the frame tube?
Another unrelated problem--- taking off the kick stand for track day, one of the bolts snapped off and now I have to get the remaining stub out? Any suggestions.
thanks in advance,
Old 05-03-2005, 02:56 AM
Default Re: steering damper clamps (pcugno749)
I'd go to Sears (or wherever else you get your tools) and get a screw extractor. Basically, it's a special bit that you drives itself into the bolt in a reverse direction until eventually it gets in so tight that it starts to back the bolt out.
That being said, I just about stripped the kickstand bolts when I removed them, so I'm not sure how easy this is going to be. Squirting wd40 or liquid wrench into the threads for a while prior to attempting this wouldn't hurt.
What track day are you doing?
Old 05-03-2005, 10:53 AM
Re: The kickstand bolts...I stripped one too. AFTER soaking them in PB Blaster.
Then I broke 2 extractors.
Then a drill bit trying to get those out.
I ended up using a dremel to gind the sides of the bolt into a hex shape, then pounding on an old socket that "roughly" fit. Got my long ratchet on it, and it backed right out.
Pain in the ASS.
Old 05-03-2005, 02:33 PM
Don't know about the damper.
About the bolt, lube it now, this afternoon, this evening and tomorrow. Get a screw extractor kit, and use the largest one that you can... that will reduce your chances of breaking the extractor.
Old 05-03-2005, 02:49 PM
Default Re: steering damper clamps (toolfan)
I have been drilling. But its a long process with gradually going up in bit size until I can get a large enough extracting bit in there. Plus my lame battery drill is not powerfull enough. Thinking of getting another that plugs into electrical. May be my bits are too dull. I was going to go to test and tune for bikes at Loudon on Thursday from 1-5 but I don't want to go without a steering damper. Still waiting for clamps.
