Help needed... - Speedzilla Motorcycle Message Forums
Old 05-01-2005, 11:19 PM
Default Help needed...
I need to remove the left side engine cover, but it seems the kickstand mount is in the way. What type of bolts hold it on? It looks like a torx head, but if it is I can't figure out what size. Oh, this is on a '95 900SS. TIA.
Old 05-01-2005, 11:38 PM
Are you sure it's not just a 6mm allen?
Old 05-01-2005, 11:58 PM
Default Re: (marvin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marvin &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's not just a 6mm allen?</TD></TR></TABLE>
That is what I thought it was. But the 6mm goes in just enough to start spinning and strip out the bolt, like it is slightly too small.
Old 05-04-2005, 04:25 AM
Default Re: (TnDuc)
some people grind the head off the bolt to make it non-auto retracting sidestand, you can easily remove the two bolts that hold on the whole side stand bracket. they are on either side of the sidestand.
