Spark Plugs? - Speedzilla Motorcycle Message Forums
Old 02-06-2005, 05:49 PM
Default Spark Plugs?
I have a 1999 and was wondering if the NGK DCPR9E is a good plug for it.
Also, does anyone know if any benefit can be had from using a thicker spark plug lead? Ducati uses 7mm. I had to move my coils under the seat. I'm using 8mm but was wondering if 10mm might be better.
Thanks guys.
Old 02-11-2005, 06:01 AM
I put in the NGK iridiums for our bikes and in my opinion, they work great.
Old 02-11-2005, 06:05 AM
Default Re: (JonHsiung)
Did you use the DCPR8EIX plug?
Old 02-11-2005, 03:11 PM
Default Re: Spark Plugs? (mr_vfr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_vfr &raquo;</TD></TR><TR><TD CLASS="quote">Also, does anyone know if any benefit can be had from using a thicker spark plug lead? Ducati uses 7mm. I had to move my coils under the seat. I'm using 8mm but was wondering if 10mm might be better.</TD></TR></TABLE>
Makes NO difference. The thickness is mostly silicone made to look "cool" somehow. Remember lures don't have to catch fish to be successful, just fishermen.
I changed the plug wires on my bike and after doing a good bit of research I opted for a set of Magnecor. Check out http://www.magnecor.com/ for more info than you ever need to know about plug wires.
