900ss / 750ss Hyperpro fork springs - Speedzilla Motorcycle Message Forums
Old 02-06-2005, 05:35 PM
Default 900ss / 750ss Hyperpro fork springs
Considering buying hyperpro progressive springs for my 900ss. Does anyone know if the 750ss kit is the same as the 900ss kit. Also, has anyone fitted these springs - what did you think.
cheers
Old 02-06-2005, 06:49 PM
Default Re: 900ss / 750ss Hyperpro fork springs (phil)
I put them in my M750 when I had it. They were mucho improved over the stock, mushy Marzocchi springs. My current 900SS has Traxxion Dynamics springs, which I tend to like a bit more than the HyperPro.
Old 02-06-2005, 10:14 PM
I'd say given the fact that Ducati uses different forks depending on model, trim level (Sport vs. Supersport) and engine size, that it may be better to contact whoever you are planning to buy them from with the specifics of your bike.
I haven't tried aftermarket springs so I can't comment on what works better. I have the stock springs. The only thing I did to my forks is change the fork oil. I switched to 5W, and there was a decent improvement in plushness.
Old 02-07-2005, 02:41 AM
I've used them & like them alot. There is always a lot of controversy over progressive springs vs. straight rate, but I prefer the progressive.
