Old 01-31-2005, 01:26 PM
Default Torque Specs - Quick Question
2001 900SS - Anyone got the torque specs for the drain plug, fliter screen and Oil sensor nut. Is it 40nm for all?
Thanks.
Old 01-31-2005, 02:45 PM
Default Re: Torque Specs - Quick Question (Kennedy)
http://www.ducati.com/bikes/tech.jhtml
MAIN TORQUE FIGURES - ENGINE
Thread x
pitch (mm) Nm ± 5% Notes
Head nuts, 2V engines (approach/final) 10 x 1.5 15 / 30 /38 Grease RETINAX - LX 2
Head nuts, 4V engines (approach/final) 10x1.5 15 / 30 / 51 Grease RETINAX - LX 2
Timing ring nuts (head / transmission) 15x1 71/61 Use new ring nuts
Flywheel / alternator nut 20x1 186 Engine oil
Crankshaft gear nut 22x1 186
Clutch nut 20x1 186 Grease RETINAX - HDX 2
Timing transmission gear nut 14x1 45
Spark plugs 12x1.25 20
Oil plug 22x1.5 45
Oil cartridge filter no. 44440034A 16x1.5 16
Oil mesh filter 22x1.5 45
I don't think oil sensor nut is on there, but if you're talking about the oil temp sensor, it breaks very easily with too much torque but i don't know the spec...
Old 01-31-2005, 03:25 PM
42nm for the oil screen and drain plug. The other I normally do by feel.
Old 01-31-2005, 03:30 PM
Default Re: Torque Specs - Quick Question (Nick D.)
Cool - thanks gents. Close enough. Considering I needed a breaker bar to get each loose, I'm comfortable with the ~40 I used.
Old 01-31-2005, 04:15 PM
For your comfort all three are the same at 42Nm and that's from the Ducati workshop manual for an 01 900SS.
Barry
