Rear wheel removal/reinstall - Speedzilla Motorcycle Message Forums
Old 02-19-2007, 03:09 PM
Default Rear wheel removal/reinstall
03 1000ss. I removed the rear wheel to have a new tire fitted. No problem using the service manual.
When reinstalling though, the whole wheel assembly (which includes the beveled washer on the sprocket side and the rear brake bracket on the rotor side) does not seem to fit in between the end of the swing arm. It seems the swing arm flexes inward enough to not allow the wheel assembly to slide in between from behind.
Has anybody encountered this and what did you do to get the wheel on?
2003 1000ss
Old 02-19-2007, 03:34 PM
Nick D.'s Avatar
Something is not right, probably with the way you have the miscellaneous bits and pieces sorted.
2000 M900 i.e.
Old 02-20-2007, 12:06 AM
check to see that your cush drive is all the way into the wheel. the spacer under the cush drive can hold it up off the face of the wheel. the flat side of the beveled washer is out. you should not need to spread the swingarm to put the wheel in.
Dan
Old 02-20-2007, 02:21 PM
Thanks guys. I think I've got all the bits in place. It seems I just have to align the whole thing a little better. I'll keep trying.
2003 1000ss
Old 02-21-2007, 05:13 PM
rotty900ss's Avatar
That washer/spacer is a PITA. I don't know how many times I put it in the wrong way.
You got the wheel off without trouble, so it should go back in the same way. That is unless you messed with the swingarm inbetween.
Next step, change your own tires.
Martin
'05 749R (Track only)(Termi half system, EVO slave, Woodcraft rearsets, CF hugger, AxlJak clutch cover, SpeedyMoto frame sliders, Starlane GPS laptimer, Yamaha throttle tube)
(Wife's ride) '04 749R red (#244)(ZARD full system, STM slipper, Yoyo slave, Motowheels rearsets, Puig DB screen, and CF hugger, heel guards, and heat sheild, custom AxlJak clutch cover)
'08 1098S black (SOLD)
'01 900ss red (reduc #992)(SOLD)
'98 YZF-600r blue (SOLD)
Old 02-22-2007, 12:35 AM
MAGNUMDUC's Avatar
http://www.ducatitech.com/info/wheelchange.html
After you do it a couple times it goes back together a lot faster.
MIKE
90NX250(The PuttPutt)
00900SSie(The First Lady)
"I'm not not licking toads"
Old 02-22-2007, 03:04 AM
CaliDuc's Avatar
+1
I dunno why, but I have a mental block on the proper way that washer goes back on.
"You can only be free when you have nothing to lose".
