Old 01-22-2007, 05:27 PM
chris steedman's Avatar
chris steedman chris steedman is offline
Default testarosso heads 900m ss monster
has anyone ever purchessed these heads ?
has anyone got any detailed pictures they would like to share of them as they seem to be a very interesting piece of work . from a really rubish picture i saw once it showed a completely redesigned inlet port ..
i do like the heads from arc fabrication they look funky too !
Old 01-22-2007, 06:14 PM
bruntr's Avatar
bruntr bruntr is offline
I have a set of Guys heads.... I don't have any pictures of the reworked ports but you can see them on his site http://www.mbpducati.ca/index.htm?cy....htm~mainFrame
Have to say they work..... I have power all the way to the redline, power range is so broad that it really doesn't matter if I run in the bottom or the top of the RPM range. He really re-works the ports and when combined with the short intakes the fuel air mixture has a straight shot at the valve. Give guy a call thats about all it takes and you will be sold..... On another note I also ran my old 750 motor with a set of heads that were ported by Bruce Meyers the previous owner of BCM, once again no complaints, while his porting isn't as extreme as Guy's it's still produced very noticable results. I have no dyno results on either motor only the seat of the pants.... no matter which direction you go porting these haeds is a must if you ever want power out of your 2 valve motor
Here is my baby.....
Current rides
1993 966SS animal
1987 700 Suzuki Intruder
