Old 12-18-2006, 04:28 PM
cugno749 cugno749 is offline
Default carrozzerias
I was looking into a set of these and was wondering what the weight savings would be over the stock 5 spoke marchesinis off the 03 ss. I called carrozzeria direct and they said a weight savings of 4 lbs. in the front and 6lbs. in the rear. Sounds inflated? Does anyone know what the marchesini figures are or where to find?
Old 12-18-2006, 05:09 PM
marvin's Avatar
marvin marvin is offline
NCRick sells carrozzerias, he can probably give you that info. motocd.com
Old 12-18-2006, 06:01 PM
PaulST4s's Avatar
PaulST4s PaulST4s is offline
When I had my Dymags installed, we weighed them and the stock wheels, and here's what my stock wheels weighed:
Stock Marchesini 5-spoke Front, with bearings, no rotors: 9.10 lbs
Stock Marchesini 5-spoke Rear, with bearings and sprocket: 19.95 lbs
These are off a 2002 ST4S, so I'm not sure if they're the same or not.
Paul
'02 ST4s
Old 12-18-2006, 10:02 PM
CrimsonCloak's Avatar
On my 748 I went from 11 lbs on the front to 7.3 lbs with a carrozzeria. That's from three spoke.
Old 12-18-2006, 10:53 PM
Ducati23's Avatar
Ducati23 Ducati23 is offline
RC Slayer
Overall 10 lbs lighter is usually about right. If want big reductions in wheel weight, it will cost a lot. Forged magnesium or carbon is not cheap no matter how you look at it.
848RS, 996S & M1100S or SF-S (soon)
Old 12-19-2006, 05:02 AM
dezmoduo dezmoduo is offline
Send a message via AIM to dezmoduo
Great weight savings at a decent price for my 93SS. And they balance out with almost NO weights with my B'stone 014's
Old 12-19-2006, 01:54 PM
Default 10 lbs.
Wow, 10 lbs. is significant. I'm hoping the lighter set up will translate to a second or 2 at the track. Rick at Cogent also mentioned that the rotors are quite heavy stock and that would be a weight savings as well. Hmmmmmm, now which color to choose. Shark skinz are all red, frame is gray, thinking black would be nice. Thought about painting the sides of the skinz silver and getting gold rims like MV agusta.
Old 12-26-2006, 06:52 AM
john S. john S. is offline
Ummm, I just recieved an email from Carrozzeria and they advised they don't make anything at this time in the 5Y or 10 spoke design for my 916. What did they have for you?
2009 Buell 1125CR
2003 Ducati 999R #189
2007 Ducati 1100S MTS (sold)
2005 Honda 600RR (totalled)
2001 Ducati 900SS (sold-shoulda kept it)
1995 Ducati 916 (sold)
2004 Ducati 999S (sold)
www.ducati-owners-group.com
Old 12-26-2006, 03:42 PM
Nick D.'s Avatar
Nick D. Nick D. is offline
I still like these in forged aluminum:
http://www.marvic.it/prod_silverstone_eng.php
If you could just get them. I called Fred at Yoyodyne but he has no ETA date.
2000 M900 i.e.
Old 12-27-2006, 02:09 PM
Default czusa
They said the 5y would work for the 99+ ss and they suggested the galfer rotors as a package:
http://www.czusainc.com/
The marvics look nice as well. Wonder what they will price the forged aluminum at. That's why I was going to go cz because marvic mags are mucho $$$$.
Old 12-27-2006, 02:20 PM
YellowDuc99's Avatar
YellowDuc99 YellowDuc99 is offline
I swapped rotors when I swapped wheels, went from stock to Braketech Axis (ductile iron) rotors. Weighed both sets:
Stock rear w/ hardware: 2 lbs. 1 ½ oz.
Axis rear w/ hardware: 1 lb. 13 1/8 oz.
Stock front: 4 lbs. 4 oz.
Axis front: 3 lbs. 1 ¾ oz.
Saved a couple of pounds, and went full floating as well!
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...' - Isaac Asimov
'99 900SS (in yellow, of course)
'03 SV650S (for the wife!)
Old 12-27-2006, 06:23 PM
mikeinwi.'s Avatar
mikeinwi. mikeinwi. is offline
these wheels are pretty light. i had a set on my M944 and my 851/926. the set on the 851 weighed in at 1lb heavier front and 1.5lb heavier at rear than the manesium March's that where on my 851 stock.
NCrick is the man to see for all things Carrozzeria. http://www.motocd.com/
see this post also. and so it begins...
Old 12-27-2006, 07:25 PM
marvin's Avatar
Hi Mike, is that rear wheel weight with or without the cush drive/sprocket?
Old 12-27-2006, 07:55 PM
cutter's Avatar
cutter cutter is offline
The handling was greatly improved on my RC51, made it feel lighter, and more flickable.
Best bang for the buck, anything lighter is going to cost a lot more, and unless you are rich or make money racing, I wouldn't think it would be worth it.
Of course you can always throw them on your next bike if it is the same size rim, so maybe the CF could be good, but it will limit your options on what bike you can buy next.
Old 12-27-2006, 08:25 PM
mikeinwi.'s Avatar
hey Marvin, that was for a complete wheel with the same tire. the sprocket/cush differ from the stock March's. i had to use a Kaw zx6r sprocket on the Carro's and their cush so it was not the exact same set up but it was close. it was apples to apples but maybe granny smith to mcintosh.
Old 12-27-2006, 10:49 PM
moto moto is offline
Forged aluminum wheels will make a difference if you have the 3 spoke wheels--but not that much difference if you have the 5 spoke wheels. Some say lighter tires will make more difference. The bike will feel more nimble.
With magnesium wheels you will really notice the ease of turn in--esp at speed.
With Carbon wheels, you really start to notice the difference in aceleration and stopping.
www.motowheels.com
05 999R
02 MV Agusta F4
02 996R
98 900SS FE
96 M900
07 1098
09 Streetfighter
Old 12-28-2006, 12:46 PM
Teufelhund Teufelhund is offline
Default Rims
The machining on the carrier was very tight. It was tight enough to impress Guy Martin of MBP and he's a former Air Canada QC inspector! Great bamg for short money.
Old 12-28-2006, 01:13 PM
jdgun_0013 jdgun_0013 is offline
I have a set on my 2005 zx6R which already has some light ass wheels, and i could very easily tell in the braking & corner speed, or is that the rolling inertia effect. Anyways damn nice quality and will be buying another set for my RC51.
