Originally Posted by blade625
is there any difference in the adjustability [2deg. increments vs. 1 deg. etc.]
between the OEM adj. pulleys and the STM units?
I believe the offset keys for the OEM non-adjusables only come in 2 deg. increments. are all the adj. pulleys the same way?
VeeTwo pulleys are infinitely adjustable. They work on a slot with pinch-bolts. Can be frustrating until you get the hang of it--back and forth--clockwise, whoops, too far! counterclockwise, whoops, too far! clockwise, whoops, too far again! and so on....
But, with patience, you
can get them
spot on.
