Open clutch cover question - Speedzilla Motorcycle Message Forums
Old 10-28-2006, 12:30 PM
Default Open clutch cover question
Hi, is there any cons regarding removing the clutch cover and fit an open carbon cover? What about dirt and dust and recommendations if it's good to replace beside the visual part ?
Also about maintenance, any special recommendations?
Old 10-28-2006, 05:06 PM
zeek900's Avatar
Official Bike Whore
I had used an open cover for awhile, but my clutch is nearing the end of its life (getting pretty loud..even for me!), so I put the stock cover on. Here's what I found:
The open cover seems to keep the clutch cooler in hot temps, and allows dust to blow right out. The stock cover keeps all that carbon dust inside, and you have to blow it out frequently in order to keep it working smoothly like the open cover allows.
There is no real worry about getting crud in your clutch unless you go through a mud pit.. The only extra you might want to invest in is stainless springs and bolts ($30), as they will rust over time.
1995 900cr rossa/ 29k mi and climbing fast / Pro Italia master cyl / high mount carbon termi slip ons / stage II Dynojet / K&N with 'custom' open airbox / Pilot Powers // 1999 Suzuki TL1000R track bike
Old 10-28-2006, 05:26 PM
throttlehead's Avatar
Originally Posted by DucDS
Hi, is there any cons regarding removing the clutch cover and fit an open carbon cover? .......
Carbon covers should be thought of as just over zero protection for the clutch in an off that targets the right side of the bike - just as another thought for your question
throttlehead
02 Ducati 998 (red)
03 Honda RC51
94 Honda CB1000 "Big One"
Old 11-05-2006, 06:26 PM
Default Open clutch covers
As already mentioned, open covers do offer bettering cooling and allow the dust to blow out. I also decided to stay away from carbon and went with stainless for better protection. Cycle Cat makes good stuff and sells through 'On Cycle'.
The only drawback is noise, but only when you are sitting on the bike and allowing it to just tick over. Pull the clutch lever in, throttle on, and the noise abates. I don't even notice it anymore.
Old 11-05-2006, 06:31 PM
Default Cycle Cat Cover
Here's a little better view of one of the styles offered by Cycle Cat.
