Where to buy ECU for 06 800 w/termi low mounts - Speedzilla Motorcycle Message Forums
Old 04-20-2006, 08:49 PM
Default Where to buy ECU for 06 800 w/termi low mounts
Looking to buy a few things for the bike, termi lows are their way but im not sure which ECU to get or where to buy it from. I'm also looking for a K&N. Where do you guys buy from? Thanks-
Old 04-20-2006, 09:46 PM
quickdraw's Avatar
get a power commander iii usb off ebay (or chris @ ca cycleworks) for an 800 monster, then get it tuned at a dynojet tuner shop or get a custom map from a member here.
don't remember where i got my air filter, but ebay or chris also. good luck.
Old 04-20-2006, 09:48 PM
quickdraw's Avatar
get a sprocket from chris while you are on the phone. best $40 upgrade there is. and if you have any tax money left over, get a nichols flywheel also, amazing difference for $150.
Old 04-21-2006, 08:45 PM
Thanks. Do I need a power commander for an 06 monster or does it matter?
Old 04-22-2006, 04:58 AM
quickdraw's Avatar
shouldn't matter. no changes from 05 to 06. they might be making it with a SS map stock now, but when i bought mine, they didn't. i called power commander, and a tech there said the one for the monster is the right one, just the map that came with it wouldn't be right. hope this helps.
Old 04-22-2006, 05:05 PM
Are you sure that the Termis aren't coming with an ECU? I thought they all did which was part of the reason they are so expensive. My pipes came with a DP ECU, but were I in your shoes and not getting the ECU with the pipes, I would go for a PCIII. It allows you to more fine-tune your motor, and allows you the flexibility to change the mapping as you make more modifications. I still have yet to get the PCIII and I can tell you that the DP ECU doesn't do all that well with HC pistons and ported cylinder heads. Maybe the fiancee will get me one for independence day or something...
