Old 04-20-2006, 05:00 PM
matteblackduke matteblackduke is offline
Default flush turn signals... again
Okay I know this has been posted a thousand times but it's been a while since I've trolled this board.
I just moved cities and lost a turn signal in the move and decided it might be time to replace the old stock signals with some flush ones. Can someone give me some links to some no-mod (ie no drilling needed) flush mounts?
Thanks,
MatteBlackDuke
2001 750S
2001 750s
CF Arrows;CF Front Fender,Rear Hugger,Heel Guards,Chain Guard,Belt Covers;Rizoma Billet Sprocket Cover;Charcoal Emissions Canister Removal;Fender Eliminator;Crankcase Breather;Clutch Slave Cylinder;Kickstand Interlock Bypass Harness;K&N Air Filter & Open Airbox Frame;Supersprox Rear STEALTH Sprocket;14T Front Sprocket;Gold D.I.D Chain;Pro-Bolt Gold Bolt Kits (various);Full Fairing Conversion;EBC HH Front Brake Pads;H4 Superwhite Headlight
Signed by #23 Doug Polen
Old 04-20-2006, 07:27 PM
quickdraw's Avatar
quickdraw quickdraw is offline
front: http://www.graphicartmotodesign.com/lights/IMG_0793.jpg
little tiny bit sticks out the back. i can take a pic if you want.
rear: http://www.kenscustomlights.com/99-05ss.htm
Old 04-21-2006, 04:49 AM
02_750ss's Avatar
02_750ss 02_750ss is offline
I was just about to order these...
http://sportbikeeffects.com/proddetail.asp?prod=3020360 Same thing, I guess. When you say a bit sticks out the back, where do you mean exactly? Do I want the ones with or wihout the plastic trim?
Thanks.
Old 04-21-2006, 05:31 AM
lgalang's Avatar
lgalang lgalang is offline
Sitting Duc
Lockhart Phillips - P1010009.jpg, b4_1.JPG. These are bulbs and should be easy to install. No drilling or rewiring.
Mototeck LED - Picture 005.jpg. These require a little work. You'll need VFX flash equalizer pro or resistors and VFX running lights kit (if you get the running light version). You’ll need to spend time if you want bullet proof wiring done.
Old 04-22-2006, 06:40 AM
quickdraw's Avatar
a tiny little bit of the existing cut-out for the stock turn signals shows in the back of the flush mounts. looks fine. flows with the shape of the flush-mounts. i got ones at a local shop with blue trim for a serious steal. thought i could paint/sharpie marker the blue to black, but i didn't like the trim when dry fitting it and ended up cutting it off. get the ones without.
Old 04-22-2006, 06:43 AM
quickdraw's Avatar
another secret...... i got two connections for RC batteries at a radio shack to connect the electrical wiring. makes taking off the fairing panels as easy as possible.
Old 05-05-2006, 06:49 PM
bzbATL bzbATL is offline
Sah Dah Tay
Thanks.
Dumb question here - how do you know which ones are for the right model?
