Old 03-19-2006, 08:54 AM
lgalang's Avatar
lgalang lgalang is offline
Sitting Duc
Question Wiring (best) for running lights
Hi guys. I am changing my front turn signals to LED flush mount turn signals with running lights. Stock wiring for turn signals have two wires. The running lights kit has three incoming and two outputs that goes to flush mount LED. In order for the running lights to work the third wire needs to be connected to a steady 12V+ source. Easier said than done – instructions say just tap to the headlight or taillight source. I also bought a 12V tester…. I don’t really want to rip the clean and secure wiring to hunt for the correct wire(s). Does anyone know or can advise which wire is best to tap into for the running lights? If anyone knows the color and exact location that would be swell so I don’t have to snip unnecessary wiring.--- thanks guys! - LG
Old 03-20-2006, 02:39 AM
02_750ss's Avatar
02_750ss 02_750ss is offline
no clue about the wiring, but can I ask what flush mounts you are using?
Old 03-20-2006, 04:22 PM
lgalang's Avatar
Sitting Duc
I'm getting this...
http://sportbikeeffects.com/categories.asp?cat=8377
Old 03-20-2006, 04:37 PM
henkieh's Avatar
henkieh henkieh is offline
illegal member
The colours of my wiring are different from the Haynes elektrical scheme
http://HenkieH.fotopic.net
Old 03-20-2006, 10:20 PM
02_750ss's Avatar
Originally Posted by lgalang
Thanks for the link.
Old 03-21-2006, 04:50 AM
cdansan cdansan is offline
go to your auto parts place and get an "add a circuit" fuse holder. this will allow you to replace your running light fuse with the new one that will have a wire to get power from the circuit. all you will have to do is extend your wires all the way to the fuse panel. this will also give you switched power at the lights. also the cover will not fit over the new fuse holder.i power my grip heaters this way and have not had any problems yet.
Old 03-22-2006, 02:32 AM
02_750ss's Avatar
Got to poking around and came across the link below, might be a solution for you ....
http://www.customled.com/PRODUCTS/MA...ic_blinker.htm
Old 03-22-2006, 04:06 AM
lgalang's Avatar
Sitting Duc
Thanks. I actually got this http://www.vfxkits.com/c229411.2.html.
I should have seen this before because i paid more for mine.
