Chain Question and Pic.. - Speedzilla Motorcycle Message Forums
Old 08-15-2010, 08:54 PM
Send a message via ICQ to jaymags Send a message via AIM to jaymags
Default Chain Question and Pic..
Anyone see the O/X rings o their chains do this...Look above the nut, looks like o-rings are getting shredded..it is happening at several spots on my chain, fairly new chain (3000 miles) and well taken of of, lubed routinely..
Old 08-16-2010, 04:18 AM
just curious....what bike is this on? Seen any tracktime? How aggresive do you ride?
Old 08-16-2010, 10:45 AM
S4RS...yes it has seen a few track days, but I have used DID ERV3 chains before on my 996 race bike and not seen the x rings do this..i maintain the chain regularly, thats how I noticed it.
Old 08-16-2010, 02:22 PM
demontech's Avatar
livin the high life
why does it look like their is wear on the outside of the inner plate? is that just a flash reflection? their should be no wear here.
Old 08-16-2010, 03:24 PM
I have seen it before, on a dirt bike as well as my old 996 track/street bike. Chain stretch will cause that. You need a new chain anyway. I would make sure the chain alignment is good when you replace it.
Old 08-16-2010, 07:31 PM
Super Moderator
Someone on another forum had the same issue. Time for a new chain, but you already knew that.
Old 08-16-2010, 10:29 PM
916duc's Avatar
Hey guys, he says there is only 3000 miles on it, so not really worn out yet! I've seen that situation before on almost every chain I've run. To me it's normal, maybe not to others.... YMMV
Old 08-17-2010, 01:21 AM
senior member,not citizen
only thing i can think of is improper tension or its off alignment...
2000 748 biposto
Ducati MacGyver
Old 08-17-2010, 04:51 PM
Thanks gents for the replies...I ordered a new chain a while back, but the mileage on the chain is not that high....the gray color on the inner links is chain lube enhanced by the camera flash.
I do think I my have been a little harder on this chain i.e. I switched back from GP shift to standard shift, because I am dirt biking again...this caused one or two rear end sliding down shifts when I was expecting an upshift . Thats not too good for the chain...
The chain is on loose, I always go towards the loose side....(insert wise-ass comment). The sprockets are wearing even and not on the sides at all so I think the chain is aligned..
Old 08-26-2010, 03:10 AM
Hey Jay,
At the risk of asking a dumb question, and since you didn't mention it, what kind of chain lube are you using?
Some petroleum based chain lubes are not good for the o-ring chains. They can swell and soften the o-rings and cause just what your pictures show.
Just a thought.
Dean
2008 Kawasaki Concours 14
1996 Ducati 916
1995 Ducati 900SS (944)
1973 Ducati 750 GT
1968 Norton Commando Fastback
1959 BMW R60
2003 Yamaha R6 (track only)
Old 08-27-2010, 01:46 AM
socal's Avatar
Email the pic to DID and get their opinion. I did that with an RK Chain after installing a chain for the first time. I was so paranoid that I did not have enough of a mushroom at the master link that I asked for them to take a look.
WSMC#644
