How do I disengage the fans? - Speedzilla Motorcycle Message Forums
Old 08-09-2010, 06:40 PM
molasses's Avatar
How slow can u go?
Default How do I disengage the fans?
Hi guys,
I'm rebuilding a 998 and I need to remove the fans and still make the bike run.
I believe the ECU checks for the presence of the fans when the bike is powered up so how do I trick the ECU into believing the fans are still there?
Can I connect the two wires that run to each fan or would that ruin the ECU?
Thanks!
molasses
Old 08-09-2010, 07:55 PM
foggy123's Avatar
my r ran without fans. not sure if that helps.
Speedzilla photogallery.
Old 08-09-2010, 11:02 PM
CrimsonCloak's Avatar
All the 749R that I've seen ran fine without fans. They would sometimes set a check engine light, but some others never did. Don't know if that's a model year change or dumb luck.
