2005 999r valve adjust - Speedzilla Motorcycle Message Forums
Old 11-17-2009, 11:01 PM
Default 2005 999r valve adjust
Just had the valves checked at 14+K and they're still within specs, though one is close to the limit. Just curious if other 05/06 999r owners are getting the same milage before adjustment is needed. Thanks in advance for your feedback.
Old 11-18-2009, 01:57 AM
kerlyb's Avatar
Send a message via AIM to kerlyb
Raced an '05 999R and track day for 2 years. All were still in spec. I heard the same from another 749R owner. I would still follow the recommended service interval.
Old 11-30-2009, 06:39 AM
DucMarauder's Avatar
Stiffy Member
Default She's a keeper!
The valve keeper system in this bike/motor was far more advanced than the models before it. A little tough to set, but once done they are good to go.....
Old 11-30-2009, 03:01 PM
CrimsonCloak's Avatar
As DucMarauder noted, the valve retaining circlips are similar to the MBP setup on the Ti-valved Ducs. Makes adjusting them a bit trickier, but they stay in spec much longer, less broken circlips, etc. Especially on the slightly lower revving 999R vs the wound for sound 749R.
Old 12-13-2009, 10:03 PM
I heard you have to remove the heads in order to replace a closer shim on the 05 and newer R bikes. Is this true?
2003 HD FLHRI
2003 Ducati 999R #189
2009 Buell 1125CR (sold)
2007 Ducati 1100S MTS (sold)
2005 Honda 600RR (totalled)
2001 Ducati 900SS (sold)
1995 Ducati 916 (sold)
2004 Ducati 999S (sold)
www.ducati-owners-group.com
Old 12-18-2009, 10:14 PM
John, that's what my dealer is telling me. The heads use o-rings vice actual metal gaskets.
Old 12-19-2009, 04:33 PM
demontech's Avatar
livin the high life
gas filled compresion ring and orings for the water passages
Old 12-19-2009, 07:32 PM
JSR29's Avatar
And they ain't cheap.
Old 12-21-2009, 07:39 PM
TomTom's Avatar
I just heard they lowered the price on those gaskets radically, not first hand though, worth looking up though.
