1098 swingarm on a 996 (anyone) - Speedzilla Motorcycle Message Forums
Old 11-14-2009, 01:45 PM
748R_bb155's Avatar
Default 1098 swingarm on a 996 (anyone)
Anyonw fitted the 1098 swingarm to the 748/996.
The local ducati shop, is fitting one to a 999R,
will post a pic, just have to download a image conversion program to get i down to size.
EO
Old 11-14-2009, 01:55 PM
I was looking at doing the same thing to my 996 I just havent found one cheap enough yet.
Old 11-14-2009, 05:17 PM
Super Moderator
916 and 999 fits, I don´t see a reason why you shouldn´t be able to fit a 1098 swinger. Apart from it being ugly, bulky and too small for a proper 190 or bigger rear tyre, why not?
Old 11-14-2009, 08:11 PM
some member
Default Swingarm swap
Why change? Is 1098 longer? I see they have seperate mounting points for the rod and shock. R
When smashing monuments, save the pedestals. They always come in handy. Stanislaw Lem
Old 11-14-2009, 08:33 PM
drthompson65's Avatar
916 swing fits 999? Hmm...
Current Ride:
Old 11-14-2009, 10:27 PM
you would need to use the stock shcok as the 1098 shocks hits the exhaust... unless you try and fit a 1098 exhaust.... it goes on and on.
paul
Old 11-16-2009, 10:45 AM
think your biggest issue will be the suspension, the linkage and shock mounting is totally different, so you'll need the whole 1098 rear end essentially and even then the rocker linkage will be in a different position in the frame and may change the performance of the suspension.... really would be a massive amount of work for no real gain (especially not in looks!)
Old 11-17-2009, 02:35 AM
Send a message via Yahoo to bella749
I have a buddy that fitted a 848 swinger to his 748. Sorry, no pics at the moment. It's not really my thing, but he seems to enjoy building frakenducs.
Old 11-17-2009, 09:32 AM
So much of the Ducati superbike range has not changed over the past 15 years in terms of measurements that i would think the fitting of the swingarm would be very easy and quite possible.... however the bike probably will not handle as well due to incorrect suspension leverage ratios and various other changes that would require a lot of time and thought to correct.
Old 11-17-2009, 11:11 AM
You can get the geometry set correctly so the bike handles well enough. I helped my buddy with his chassis measurments when he put a 998 swinger on his 999 (don't ask me why). The chassis points are close enough that a custom shock gets everything where it needs to be. To me, the expense and effort isn't worth it, but some folks like projects.
Old 11-17-2009, 05:30 PM
CrimsonCloak's Avatar
I'd be interested in that 748 swingarm build because I'd like to have a lighter swingarm that is longer and more rigid. Would cost less than the $3500 that the mag arms are bringing to boot. I have pretty good access to machinists and slightly scuffed Duc parts, so it's only a matter of time before I come across the needed ingredients.
Please post as much information as you can come by, or just pm me with any details you can garner from your friend.
Old 04-07-2010, 11:50 AM
Any pictures?
748R '02 - Fantastic Bike
748SP '97(sold)
900SS '94(sold)
Cagiva Prima R '95 (sold)
Old 04-13-2010, 04:56 AM
Old Baldy's Avatar
I've a senior member
I'm looking to do the opposite....put on a 999 arm, linkage, shock, brake and wheel on my 996 frame.
Wanna do a swap?
Old Baldy / WWBO #451
Ducati 996
Kawasaki KLR 650 '02
Kawasaki KLR650 '06
OB's Blog
Old 05-27-2010, 03:54 AM
BMiller's Avatar
That's Right....
Here ya go: 748 w/ 848 sssa & pipes - Ducati.ms - The Ultimate Ducati Forum
Old 05-27-2010, 05:16 PM
TomTom's Avatar
Someone told me the streetfighter swing is even longer.
Old 06-07-2010, 08:13 PM
senior member,not citizen
Default id do it
anyone chime in on this????
2000 748 biposto
Ducati MacGyver
Old 06-07-2010, 09:48 PM
Well the wheelbase is about 2" longer on that model. It looks like most of it comes from the arm...that's probably too long unless you are drag racing.
