I got a new engine for the 996.
got some primary trouble with the tb's but it worked out after a couple of hours thinking.
The horisontal got vertical and then swapped the linkage 180 degrees and they turned 996 but mirrored :=)
Anyhow its doable.
Not a very clear pic of the tb's but the engine is in there and it will work.
I am documenting it very well and I'll have a report in 2 months or so.
I will keep it very 996sps still, nothing to reveal it other than a trained eye at the rear cylinder.
I'll still use the same exterior that I had before, so the 57mm corse will still be there and probably much better spent now.
