Temp Gauge?? - Speedzilla Motorcycle Message Forums
Old 10-18-2009, 11:13 PM
TrickLidz's Avatar
lidzduc.blogspot.com
Default Temp Gauge??
1998 748. Key ON temp gauge pegs to full HOT and stays there. (bike is cold and has not been run). Key OFF gauge goes back "0". Voltage at coolant temp sensor shows 6.5V.
Any ideas?
http://lidzduc.blogspot.com/
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 04:38 PM
TrickLidz's Avatar
Anyone??
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 04:57 PM
G8RDuc's Avatar
Originally Posted by TrickLidz View Post
Anyone??
It's either the gauge or the sender...I'd start with the sender since that's more likely.
Jimmy
Go Gators
2000 748R - R.I.P.
2001 996
Old 10-19-2009, 06:47 PM
TrickLidz's Avatar
How do I test the sender??
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 06:49 PM
G8RDuc's Avatar
I'd just replace it...
Jimmy
Go Gators
2000 748R - R.I.P.
2001 996
Old 10-19-2009, 07:14 PM
DukeDesmo's Avatar
Default Testing temp sender...
Taken from workshop manual;
916 & M944
Old 10-19-2009, 10:21 PM
TrickLidz's Avatar
thanks. How about a test for the single wire sensor that feeds the gauge only??
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 10:33 PM
DukeDesmo's Avatar
If single wire then test resistance between body (ground) and wire.
916 & M944
Old 10-19-2009, 11:04 PM
TrickLidz's Avatar
thanks, will do. seeing as my gauge pegs to full hot when I put the key ON...I'm thinking the wire from the gauge to sensor is shorted to ground somewhere! Right?
I get less than 12v at the sensor wire.
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 11:12 PM
TrickLidz's Avatar
I understand that the sensor (top of diagram, orange/black wire) should ground to the housing where it's threaded, correct. Then why does it not show it going to ground in the diagram? Like the starter solenoid?
I may have too much sealant around the threads (I had a different sensor there when I used my digital dash for the track, so I'll check that.)
I quess my main question is- grounded wire will send the gauge to FULL HOT---open wire- gauge does not move??
TIA
'Lidz
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 11:37 PM
DukeDesmo's Avatar
According to the spec in the manual; lower resistance = higher temp, so a directly grounded sender wire would give full temp. It does sound like the sender is no good, which is 'good' news as it must surely be a cheaper fix than a new gauge.
916 & M944
Old 10-19-2009, 11:51 PM
TrickLidz's Avatar
I too would think that the sensor is NO GOOD....BUT...the gauge pegs full hot with the wire removed from the sensor also!!
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-20-2009, 07:55 AM
vij vij is offline
www.virdung.net
Deleted
MHR 900 1984
S4 984 2002
www.virdung.net
Old 10-20-2009, 04:47 PM
TrickLidz's Avatar
Thanks ALL.
Found the problem...BIG Ahaaa moment!!
Decided to take the gauges off and check the back for the proper connections....and...sure enough the water temp connections were ass backwards!! I had removed them and reinstalled in the wrong places
Here's how they should be connected (if anyone cares at this point)
Thanks all!!!
'Lidz
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-20-2009, 04:48 PM
TrickLidz's Avatar
Damn, sorry for the HUGE pic!!
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
