748 wiring diagram? - Speedzilla Motorcycle Message Forums
Old 10-17-2009, 12:21 AM
TrickLidz's Avatar
lidzduc.blogspot.com
Default 748 wiring diagram?
Anyone got a color picture of the wiring diagram for a 1998 748 they could link me too??
http://lidzduc.blogspot.com/
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-17-2009, 12:57 AM
rjjablo's Avatar
Default Wiring Diagram
I could Scan the one out of my Haynes if you want. Later tonight though I have to go put the chain back on mine so I can actualy ride it once this year.
Old 10-17-2009, 01:28 AM
TrickLidz's Avatar
Thanks,
But I'll be home later so I can check my own manual.
Needed to check something before I got home.
Thanks again.
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-17-2009, 11:11 AM
DukeDesmo's Avatar
Here you go;
916 & M944
Old 10-18-2009, 03:23 AM
TrickLidz's Avatar
Duke, thanks, just finished rewiring the 748--everything came out great.
One problem. Can someone explain how the voltage circuit for the temp gauge works? When I turn on the ign. the gauge pegs to full hot (I can't start the bike yet, it's in the basement). Following the diagram above to the coolant temp sensor (top) orange and blk wire goes to the gauge along with blk (ground) and blue (source 12v) so the org/blk is (signal)..right? The wire at the temp sensor shows about 6-7v (regardless if it's on or off the sensor).
I assume it works like the tach and TPS as the wiring's the same.
After 10 hrs of wiring...I'm too tired to figure it out now
Thought I'd ask for a short cut???
TIA
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-19-2009, 06:46 PM
TrickLidz's Avatar
Got the wiring done!!
LIDZDUC
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-20-2009, 10:01 AM
TIA
Have you got 12v on the blue wire?
Old 10-20-2009, 07:24 PM
TrickLidz's Avatar
Temp Gauge??
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
