Upgrading 03' 999 DSSA to 05' DSSA - Speedzilla Motorcycle Message Forums
Old 10-04-2009, 04:58 PM
Default Upgrading 03' 999 DSSA to 05' DSSA
Would like to change my 2003 999 swing arm to the 2005 swing arm.....problem is I have a Termignoni 54mm full exhaust. I know that the Termignoni slip on will fit, but there are issues w/ the full exhaust.
I know this has been discussed before, but are there any new suggestions, anybody recently modded their 54 or 57 to fit the new swing arm? Anyone know of a motorcycle exhaust fabricator who might do this type of work? Any feedback would be appreciated!
Old 10-04-2009, 11:24 PM
Super Moderator
04 57mm exhaust on 999R with SBK swingarm, does fit although it was tight.
Old 10-05-2009, 04:21 PM
Send a message via Yahoo to bella749
It really depends of what system you have. The Termi 54mm system was redesigned post-'04 to fit the braced swingarm... those are the ones you see with the "oval" shaped or "flattened collector pipe. However, I have the "round" 57mm system on my R, with braced swingarm and it clears fine; tho that system was designed to fit the R.
Only way to know for sure is to mount it up, or take measurements. I think you'll likely end up with clearance issues on the collector pipe; the clearance can probably be fixed with a BFH without any penalty in power output.
Old 10-05-2009, 06:21 PM
I have seen the 05+ braced arm w/ the larger 57mm exhaust (round) not flattened..... fit...I mean there's nothing different, the exhaust can only be routed a certain way whether it's a cast or braced arm. The shock set up the same in each swingarm. There's a substantail relief in the bottom of the braced arm for exhaust clearance......I would hate to change the 54mm because it runs so well w/ this size exhaust and it's dedicated ECU. I haven't seen any 54mm Termignoni Flattened/oval midpipe kit, just the 57mm. A BFH The only way is to fit it up and take a chance-there's a ton of room under my cast 03' arm, but it's tight on the outside of the swingarm....thanks for your input!
Old 10-05-2009, 08:34 PM
Like I said, You can mock it up and see. IIRC, the 54mm tucks up closer than the 57mm. I have the round pipe 57mm on my '05R; it sticks out quite a bit. The interference will be with the collector and the braced swingarm aft of the relief. I dont think it's much, but enough that warranted a design change to the flattened collector on both the 54 and 57mm systems for 2005... I had to wait like 6 months for the updated 54mm Termi when I bought my 749 in '05. It was 54mm, and it was flattened
Old 10-06-2009, 01:23 AM
TrickLidz's Avatar
lidzduc.blogspot.com
"slight thread hijack"
Will the 05 braced swingarm mount on the 2003 bike with no mods (assuming I use my stock slip on exhaust)?
Is it longer than the 03 arm?
Anyone done the mod?
Best place to purchase the braced arm?
TIA
http://lidzduc.blogspot.com/
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-06-2009, 09:49 AM
TIA
Straight exchange. You missed out because a couple months ago there was a guy who wanted to trade straight across, his braced swingarm for an 03-04 grey swingarm. I didn't do it because I like the look of the earlier swingarm better.
2003 HD FLHRI
2003 Ducati 999R #189
2009 Buell 1125CR (sold)
2007 Ducati 1100S MTS (sold)
2005 Honda 600RR (totalled)
2001 Ducati 900SS (sold)
1995 Ducati 916 (sold)
2004 Ducati 999S (sold)
www.ducati-owners-group.com
Old 10-06-2009, 09:50 AM
I've heard of fitment problems with the 57mm but none with the 54mm.
2003 HD FLHRI
Old 10-06-2009, 05:54 PM
TrickLidz's Avatar
Thanks. Damn, would have done that in a heartbeat! But now mine is scratched
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 10-08-2009, 08:40 AM
Is there some clearance issue with the later swingarm on the fairing on the left hand side or something?
Rod
2003 999R #0069
