Anyone notice a distorted axle? Specifically, on the big end across from speedo drive and nut? The side where the locating tool fits. Slightly less than round where the compression valve bore intersects the axle bore? If so is that overtorque or they all do that? It is thin. I think it could be such that it resisted the leg centering itself withthe settling bounce.
I think this is typical "ovaling" of the thin walled end of the axle. Would be worse if over-torqued. I understand that titanium axles don't have this problem.
Just wanted to know it is not just me. I believe a titanium axle would alleviate this ovaling. Should have known one was offered as is every other part for these things. I dressed mine and it goes in ok so I will just research the Ti axle for now. Ciao
For what its worth, I understand that the Ti axles aren't a lot lighter however I've never been one to care about functionality when adding bling to my bike - although I contend that the neon lights I've mounted are a great safety feature.
